Sunroof Wind Deflector
twernst
Manahawkin, NJ
Has anyone found a wind deflector that works with the panoramic sunroof? Especially a version that does not get tapped to the roof?
Wayne Decker
New York State
It has one built in that works well. The only time it doesn't is if you hit the open button twice and it opens another couple of inches. Then you get the thumping. But on the normal, one-button-push opening it's fine. At least for me.
twernst
twernst
Manahawkin, NJ
While agree the factory netted one works well. I prefer the weather tech one I have had for other vehicles it just seems to work best and allows for really good air flow.
8131full
Las Vegas
speaking of sunroofs... does anyone else have an annoying gap in the (for lack of a better term) sun shield? The sliding fabric bit under the glass? Mine has about a 3/8" gap when its supposed to be fully closed. When the sun is right, it shines right though. Besides, every time I close it, it seems to close a little less than before (thus leaving an even bigger gap).
Artie
Georgia
No gap on mine.
Randy Schmidt
Illinois
No gap here...
harrelljr99
Royston, Ga
Do you have a weather tech one on your expedition now? If so pictures please
armoredsaint
gaps are good in hot chicks
NukeLife
Charlotte
No gap on my’18.
This should be an easy limit switch adjustment for your dealer. You may even get lucky and find it only requires a program update—to allow the system to “re-learn” the home position, similar to an encoder having to re-learn where zero degrees is.
