LameSuburbanDad
before I even get my project started...
Hi all! New member New-to-me 1999 expedition 4.6 4x4.
the truck is getting a brand new modded engine, little things, bored .20 over, better cam, upgraded wires, E-3 plugs, synthetic fluids, for a little extra punch.
I was curious in running through my project ideas to see if there are any inherant problems anyone may foresee. or advice that can be given.
here we go.
2/3 suspension lift with torsion cranks and spring spacers
3 inch BL
gap guards
paint all visible under carriage areas (like wheel wells, the part of the frame that become visible) black to match the body color.
KMC wheels xd797 SPY 17x9
(LINK http://customwheel.com/custom_wheels/product_info.php/products_id/23739)
Nitto Dune grappler DT 315/70/17 tires
(LINK http://www.discounttiredirect.com/d...o?pc=40367&typ=Truck/SUV&tmn=Dune+Grappler+DT)
I think I may install a router with an antennae booster for my laptop.
Try the GOTTS MOD with a K&N drop in.
Find a CUSTOM programmer/tuner.
Go with a decent drilled/slotted rotor front and rear with ceramic pads.
A new grille with 2 6'' lights built in the front (similar to the new mustangs, with blue bulbs in place of stock.)
Black gauge faces that glow white when turned on.
Super bright white LED interior lights with a few extra lights for fun (like wired into the center console, or under the dash to illuminate the foot area under the dash.)
Wire in aftermarket 110v outlets.
Gps/dvd double din head unit.
Maybe try to mod the rear door skins to accept 10'' subs.
New black projector headlights with the CCFL HALO and 10,000K HI/LO bulb conversion.
New HALO fogs with blue lights.
The old tried and true Ventvisors.
LED taillights.
Custom exhaust (only have it figured out that I want dual pipes, no word yet if I want a true dual exhaust, if I do then I will also change to Headers, if the new engine doesn't come with them already.)
run a longer shock for better ride quality. like a Rancho.
Anti roll/sway bars front and rear to keep my planted on the street, or trail.
I also want to try custom painting all my gauge needles just for fun.
also the ONLY chrome trim on the truck will be on the bumpers, the rest, i.e. the grill and chrome around the headlight, will get a shadow paint to make it all look like Pricey "Black Chrome."
It will be fully De-badged.
Might tint the windows a smidge, like 35%.
Throttle body spacer.
Bigger diameter throttle body.
Electric cooling fans.
If I can find a STEAL-OF-A-DEAL on a hood like a few of other members, I'de like to have one.
Smoke the LED tails and third brake light
Remove the running boards and replace with single steps for each door (also black.)
Take some of the interior pieces and make them jet black.
Add a tear-drop light to the drivers A-pillar. (black)
Run some dynamat.
Air horn
Viper remote start/alarm
And finally paint some of the parts under the hood jet black, to dress it up a little.
That covers my ideas for now, although I can't help but think I've forgotten a few things, but that's ok I have lots more ideas on things I want to try out
So what do you think? I know it seems like a lot of stuff, but spaced out properly shouldn't take long at all to complete. I have most of the knowledge I need to complete the projects, now it's a matter of finding those "just right" deal
here we go.
3 inch BL
gap guards
LED taillights.
Run some dynamat.
Air horn
