Design Miscue
Bill Schell
Montana
I was looking at the backend of an Explorer and then an Edge yesterday at a traffic light and thought, "man those dual exhausts look nice". What was the Expedition Team thinking when they signed off at final design review? :yucky: I fully expected the 2019 model year to get changed...anyone know if the 2020's will?
Rancidlunchmeat
2019 XLT FX4
I don't know what you mean by this.. nothing is changing on the 2019's..
No, the 2020's do not have dual exhaust either.
https://www.autoblog.com/2019/08/16/2020-ford-expedition-review/#slide-2160370
dlcorbett
Air Force
tx
The mid cycle refresh is slated for release in 2021 as a my2022 with the hybrid model headlining the change.
stricnine
I for one can’t stand dual exhaust. Why? Because I tow! Nothing is worse than two pipes blowing exhaust on your legs and in your face while hooking up a trailer. Shutting off the truck to avoid it sucks too, so turn downs and side exhaust have my vote! I am interested in a polished replacement for the factory resonator but have not committed to it yet.
Black
Kentucky
single side exit exhaust on trucks!!!!
Not just towing but loading and unloading stuff.
I need to Get around to doing the side exit
Meeker
Calgary, AB, Canada
I'd be in for a side exhaust too - this is definitely a "first world problem" but I park backed up against the garage door (outside) and when I start up on cold mornings, the exhaust is thick enough (i.e. visible) to block the garage door optical sensor and I can't close it. I have to drive ahead a few feet and then hit the button...
Sounds miniscule but this has caused me to leave the door open accidentally. I'll get over it... :)
Deadman
I hate rear exhaust on vehicles with a hatch and hitch. The damn steam is always in your face or on your pants and such. It doesn't hurt anything but its just stupid. My previous car had hi flow cats and rear exhaust and every time I hooked a trailer up or opened the rear hatch the heat and steam and stink was in the car or in my face. Good luck to GM on their shiny exhaust pipes on their new anemic 5.3L.
TobyU
To each their own but this gets my vote.
NO doubt the look is better! What did we do to all our muscle cars and performance cars?? Put duals on them.
I dislike that so many new cars have duals because it is SO much extra cost especially when you have to get exhaust work done.
No real performance advantage in a a daily driver or an SUV. I have never burned my tires in any of my SUVs or ever seen a redline or even high rpm shift.
I have fast cars for that.
I see the desire for side for convenience with hitches. Trucks almost always had a side exhaust. Maybe because with a rear when the tailgate is down it pools fumes under there and bad on paint etc.
Artie
Georgia
bad on paint etc.
This is true. I think the Lincoln Aviator has duals but they exit below the tips instead of the duals that show out behind the bumper for this very reason.
Fozzy
Riverton
If their not a true duel set up why waste your time? Plus I haven’t heard a good sounding exhaust note from any Ecoboost. The GT sounds ok, until you hear any other super car.
Lou Hamilton
My Honda Pilot had dual exhausts straight out the rear. I burnt myself too many times while unhooking my camper after a drive to a campground.
Although, I haven't towed yet, I am glad the exhaust is not dual nor sticking out the back.
scottdm
Western PA
The primary reason that manufacturers have the exhaust exit downward prior to the actual exit of the SS exhaust tips is to prevent soot buildup on the SS tips. I'm pleased that the Expy has a traditional exhaust outlet with no SS tip. On prior vehicles, I'd have to polish those SS tips fairly frequently to keep them looking decent from all the soot buildup, water stains, etc.
rjdelp7
2000 XLT
NY
Its not a true dual. It's 2 to one, then 1 back to 2. Dead weight. In some cases a single exhaust, makes more torque.
TobyU
Yep and everyone is right about which way produces more.
Even the H pipes create more in some areas that straight true duals but I think IF you had the ability to test all different sizes of pipes and mufflers you could out perform h pipes and 2-1-2 systems. I know you could in some rpm ranges.
The problem with comparison on what is available is that you can compare h pipe or 1.5 inch duals only. Many cars cant have 2 1/4 like we used to put on them.
