2016 Expedition Fuel Pressure Driver Module Location ?!?!
Can anyone tell me the location of the FPDM on the 2016 Expedition EL Ecoboost ?
Not sure what you’re asking, but the fuel pump pressure switch shut-off is in the left rear cargo compartment with a removalable cover.
I own a 2015 Ford Expedition Limited 4x4.
M
mtnxtreme
New Kingston NY
bobmbx
Thanks, but this is a 16, they're showing 08, I looked everywhere, nothing !
Follow the cabling for the fuel pump from the point where it exits the fuel tank. You'll eventually find the controller. Its probably bolted to the top of a frame member near the fuel tank.
Matthew Jenkins
Colts Neck, NJ
Find it?
I have a 2012. I believe it is called the Fuel Pump Control Module (earlier years it was FPdriverM) . It is located ON TOP of one of the cross members. In pictures I've google is looks easy to spot, but in my Manual the drawing has it hidden on top of the cross member. It is also a bit smaller than previous years.
M
mtnxtreme
New Kingston NY
Yes I found it, same place as on the F150, right above and behind the drivers side rear wheel is a little panel, three screws, pop it off, its right there on top of frame member, I swapped it out, but it was the in tank fuel pump, 70k dollar vehicle, 45k miles already needs a fuel pump, go figure !
Matthew Jenkins
Colts Neck, NJ
Fuel pump? What were the symptoms? How did you know to replace it? I'm testing mine this weekend. Fuel pressure test and a leak down test. I have hard cold starts. I'm thinking there pressure isn't holding when the truck sits for a while.
M
mtnxtreme
New Kingston NY
This truck died are times was able to restart and drive and then just died altogether in the same day. The code will be low fuel rail pressure !
