Update all versions of Ford Sync 3 to the latest Sync 3.4
AAOO
emil_greus
Romania
Can somebody summarize what 3.4 is bringing additionally to 3.0?
I mean, is really worth the risk of bricking your APIM for the 3.4 variant? ;)
I have the 3.0 and is working smoothly.
Lou Hamilton
For me, the main reason for doing it was the updated look. The 3.0 seemed so mid-90's in my opinion.
I am not 100% sure if you need to be on v3.4, but there is also an updated map database (v1.18). I rarely use the built-in Nav since I have everything setup in Waze, but I like the latest and greatest tech stuff. I am not a programmer, but I work in the IT field as a network design engineer and do a lot of beta testing for various things (Apple, Windows, network equipment vendors, etc.). I don't know if that means much or helps with your decision, but sometimes, "if it ain't broke, don't fix it". ;)
Lou Hamilton
If you are able, could you post a couple of pics of the updated look?
The bluish one is the Ford MY20 theme. It is basically smoothed out and less faux buttons.
The greyish bronze is the Lincoln MY20 theme. I don't know what the old look is for Lincoln, but I will be making a permanent change to it once my ODBII module gets delivered. :)_.jpg _-2.jpg
A
AAOO
@Lou Have you looked at the ford blueish version in night mode yet? You should be able to set it in settings to stay on the dark theme regardless of the ambient light.
Lou Hamilton
Yes, but since I have the Black Stealth interior, I like the more black-like theme.
Thanks for looking out, though. :)
Meeker
Calgary, AB, Canada
I can confirm that map version 1.18 is available on v3.0 (on my 2018 Expy).
One thing that hasn't been fixed in v3.0 is the Waze speed being off by 10-20%. That is fixed in 3.4.
Artie
Georgia
The greyish bronze is the Lincoln MY20 theme. I don't know what the old look is for Lincoln, but I will be making a permanent change to it once my ODBII module gets delivered. :)View attachment 33831 View attachment 33832
This Navigator theme you’re showing is practically identical to what I have in my 2018. The only difference is the addition of the ‘climate’ option and slightly smaller font on the bottom row of options. Apart from those two items there is no other difference.
TxBrian
DFW
How do you set the Lincoln theme ? I assume forscan but didn't see it detailed.
Lou Hamilton
Under APIM:
7D0-01-02 8xxx xxxx xxxx (This changes it from Ford to Lincoln)
7D0-02-01 xxxx x2xx xxxx (Sets the theme to Lincoln Bronze)
- or -
7D0-02-01 xxxx x3xx xxxx (Sets the theme to Lincoln Black Label)
Fozzy
Riverton
Under APIM:
- or -
The screen you like is the black label?
Gumby
Beaumont, Alberta
Has any really bricked their APIM? I mean it's pretty straight forward or so it seems. I am hesitant, but really interested to do this. I have Sync 3.0 v19025...it should work?
TxBrian
DFW
I've done both my Raptor and Expedtion (both 2018's), no issues.
TxBrian
DFW
Yes. It is more black with white accents and less dark bronze with gold/bronze lettering.
Have you checked out the Ford GT theme in night mode? It also looks really good .
Fozzy
Riverton
I can only change the splash screen with Forscan. How do you change the theme?
Gumby
Beaumont, Alberta
Hmmm...ok I think I might give it a go. Question on the maps. In the link they talk about UK and EU are NA maps included? I would hate to have to navigate to Big Ben or something lol.
