Jingram1083
So first, the front fan, which is dual climate control stopped working. Wiggles the blower motor resistor harness and it worked for a short period. So I then changed the harness. Still wouldn’t work, and if it did, only on high. So I changed the blower motor resistor. Now it works on low, and on high, but on speeds in between it fluctuates intermittently up and down with speed.
second, I have heat and a/c up front, but no heat in the back. Checked the lines that run under the truck to the back. There are 4. 3 big, 1 small. The 2 outside big lines are hot, and the other 2 are cold after running vehicle. Kinda lost at this point. Just want heat in the rear, and my damn fan to work on the setting I choose lol.
![20200719_114658[1].jpg 20200719_114658[1].jpg](https://www.expeditionforum.com/data/attachments/35/35384-2ee242f40e55f4c3c253d2e4b6c877f4.jpg)
