cd less and a possible work around ?
William R Kohut
usa
i bought my wife a 2019 ford expedition max. Obviously it doesn’t have a cd player or an aux cord. she owns a cd player that connects with an aux cord . is it possible to use a usb to a female aux connection to have it work or do i have to purchase a usb cd player?
wakeboarder
Fort Lauderdale, FL
I dont think there is a Bluetooth option. You have to have a very specific aux to USB adapter. Most adapters are usb to aux. I use a fm transmitter which works ok for aftermarket RSE. Uploading the music to a phone or flash drive is probably the best option.
Dclr
Arkansas
I'll be honest, I haven't owned a portable CD player since the late 90's but can definitely help. PM me and I'd be happy to walk you through the process. There are so many variables, it's difficult to iron out in a single post.
MxRacer965
Hudsonville, MI
Bunch of options...probably the easiest and lowest tech with worst sound quality would be to use an FM transmitter. Plug in to the CD player and tune your radio to the transmitters frequency and you’re done.
You could get an iPod and plug in via USB or Bluetooth.
Ditto for an Android phone or iPhone.
You could also store music on a USB memory stick.
You could pay for a service like Spotify or Apple Music where you can create your own play lists and stream via Android or iPhone.
Most of the options above would require you to download music to a device, be it Android, iPhone, or memory stick. That means you need to either rip a CD (convert the CD to individual song MP3 files), or buy digital copies of your music.
The subscription option gives you access to massive quantities of songs, but comes with a monthly cost.
The first option would probably cost less than $20 but results can be iffy depending on how crowded the airwaves are in your area. To avoid that problem when I lived in Chicago I used to have an FM transmitter for SiriusXM radios that weren’t integrated into the car. But those wired between the factory antenna and the radio and ensured a solid signal. You could still do that but it would mean you have to partially disassemble the dash.
AKentPhoto
New Orleans
Putting them onto a USB is by far the best option, especially safety standpoint but if you want to be a hero in multiple ways you can start here....
AUKEY Bluetooth 5 Transmitter Receiver, Wireless Audio Adapter with aptX Low Latency, Dual Links for for Headphones, TVs, Home Stereo Systems and More https://www.amazon.com/dp/B07QXY11BQ/ref=cm_sw_r_other_apa_i_J3hzEb2E0XAQ6
I have the old version of this and it is so handy in so many ways. It will work as a transmitter to transmit to the car, only issue is track skipping won't work. She will have to do it on the CD player. When she gets tired of that (and you save the day again by ripping her CDs to USB stick) you can use it to connect two sets of BT headphones to a single source. Ie kids can watch something together in the back, you and wifey can watch a movie together on a plane because it has a built in battery etc. Etc. Etc... Endless possibilities...
MxRacer965
Hudsonville, MI
Good call, forgot about BT transmitters.
that said I have one of these from Anker and it SUCKS (probably why I forgot I have it). Not reliable enough. Maybe things have improved or this brand is better, but decoding blinking lights when there is inevitably a connection issue stinks.
AKentPhoto
New Orleans
@MxRacer965
How was it unreliable? Would it drop out? Pairing on a plane full of other bt headphones could be a pain/problem but mine has been 100% reliable once paired. On planes it's great because it works all the way to the bathroom.
MxRacer965
Hudsonville, MI
Connecting to headphones that were previously paired was EXTREMELY unreliable. I used those head phones to pair to my surround sound via the BT transmitter while working out in the basement and watching TV as well as to my phone when at the gym. It NEVER works right unless I screw around for 10-15 minutes. I guess if you have a dedicated set of devices it may be more reliable, for me it’s been garbage. So much so that I threw the BT transmitter in a drawer and forgot about it until it was mentioned now.
wakeboarder
Fort Lauderdale, FL
@AKentPhoto
Can you confirm that you have paired this with your 2018+ Expedition or Navigator? I don’t think most Bluetooth transmitters will pair with the newer Fords. I have tried something similar and it did not work.
I would suggest the op read through this F150 forum thread as there is quite a bit of information on a similar topic.
https://www.f150forum.com/f118/no-longer-have-3-5mm-line-now-what-do-i-do-350965/index7/
AKentPhoto
New Orleans
@MxRacer965
How long ago was this? Was it BT 5.0? That makes a huge difference. The newer BT standards are waaay better.
This one seems to be the newest gen with an AptX Low Latency mode... The optical in/out is a nice touch as well for all the audiofiles. The fact that it comes with all the cables shows the company isn't totally cheapo.
TaoTronics Bluetooth 5.0 Transmitter Receiver with Codec Display, aptX Low Latency Wireless Audio Adapter for TV Home Audio System (3.5mm AUX, RCA, SPDIF in/Out) Dual Link, 24hrs Play Time https://www.amazon.com/dp/B083TF9NK8/ref=cm_sw_r_other_apa_i_7-nzEbK0JRM4A
@wakeboarder
I personally cannot, my truck isn't here yet and the dealer is closed today. I'm going to a rather large Crawfish boil today so if I see something with sync3 I'll borrow the keys.
rjdelp7
2000 XLT
NY
Rip your CDs to any computer and move the files to USB memory stick.
Rancidlunchmeat
2019 XLT FX4
You can also upload all your music to Google Play or Amazon music. I uploaded all of my CDs to Google Play without any charge. I think for Amazon you need Prime, but I'm not sure. Bypasses the USB necessity but then you're streaming music and charges may apply.
No members online now.
Landsbutter
