Rear Differential Fluid Change
Hoos95
I have a 2007 Expedition EL w/ 360K miles. I am the second owner and am not aware of the rear differential fluid ever being replaced. Axle code 16 meaning it is an open differential not needing the 4oz friction modifier additive, according to FordTechMakuloco on YouTube, but should I add anyway?
Before I start this project, I wanted to confirm the fill plug and the drain plug on the differential. I took pictures of what I assumed to be each, the first one below being the fill plug and the second one being the drain plug. Do I have that correct?
According to the manual, the new fluid will be Motorcraft SAE 75W-140.
07navi
Mt.Shasta California
Plugs are right and most don't even have the bottom one. Why would you want to add modifier if it doesn't take it?
H
Hoos95
Good and thank you! I was pleasantly surprised when I noticed there was a drain plug and didn't have to take the cover off.
As for the modifier, FordTechMakuloco says: "You can add friction modifier to any axle and no harm will be done... it is better to be safe than sorry and just add one entire bottle with your new axle." I just wanted gauge opinions.
Shantheman73
Kansas City
Is that 360k miles or kilometers?!
2007 Ford Expedition Limited
07navi
That's only needed for the clutches if the limited slip rear end. Makuloco said you could but maybe you took it wrong. Open diffs don't use it.
07navi
That's SYNTHETIC 75-140 and it is interesting that the rear end lasted that long with no change but it did have the synthetic in it. Ford recommends that you change it every 100k miles (and use synthetic).
71Rcode
DFW Texas
Changed the fluid my front and rear diffs and transfer case last week. Was also thrilled to find the drain plug on my 2011 rear diff just like you had pictured. Very easy to do by the way. Used Motorcraft SAE 75W-140.
osteodoc08
GA
Most of them have the modifier added. I know the Mobil 1 I always use has it added already. Hope it doesn’t come out as sludge.
07navi
It calls for synthetic but that will probably be OK
FeO2
For those with 4wd, How about the transfer case? Lube change with what lube?
71Rcode
DFW Texas
I used Mercon LV. I placed a big rockauto.com order for all the needed Ford fluids.
H
Hoos95
Did you buy it new? Do you know if the chain tensioners or variable cam timers were ever replaced ?
I'm the second owner and got it with around 90K miles. To my knowledge, tensioners and timers were never replaced.
H
Hoos95
Did the rear diff fluid replacement today. To my surprise, removing both drain bolts were relatively easy and only took a little bit of strength with a breaker bar, didn't need to use any penetrating fluid.
After 360K+ miles, the fluid came out a very dark brown and the magnets were covered in thick and compacted shavings. The fill plug had more debris than the drain plug. I had to use a box cutter to break away the shavings.
Before and after pictures:
Shantheman73
Kansas City
View attachment 35052 View attachment 35053
Nicely done!
Did you just fill them up to the fill plug? Or is there a preset amount they are supposed to take?
H
Hoos95
Nicely done!
I filled it up to the plug which ended up being the same capacity as the manual said.
