Show your Lifted 3rd Gens
RenegadeBad_Dog
South Carolina
Anyone know if this would even be worth buying? It's only a 0.5 inch level and I'm worried that that isn't big enough to even make a noticeable difference.593c68c2ba39cf3dbc87c584ebc0c755.jpg
Sent from my SM-G973U using Tapatalk
TyTy12
Finally got my lift installed. Went 2.5/1.5 and Bilstein 4600s on all four corners. Added '17 Raptor wheels with 34" Cooper Discoverer AT3 XLT tires. Huge difference in ride (improved) and no rubbing at full lock anywhere.
48995910447_b3d681dcf7_k.jpgIMG_20191009_175733
Did you change the control arms? If so what did you switch too?
07navi
Mt.Shasta California
I’m serious, they can’t keep banning me when other members still troll around. I’m back to see what’s going on in the world of 3rd and 4th gens. If they ban me again, I’ll just keep coming back
On the FTE truck forum if they ban you it's for life.
Rexpedition
City of Norfolk, downtown mall parking garage is pretty much 2” taller than my max height. I barely fit. Hotel parking garages are a different story. I do not fit. DC garages I also do not fit
That garage is huge! Lol... Norfolk airport on the other hand ...
BTW, Chesapeake here :wave:
Not lifted... yet.
Moderator
You realize this post was from 14 months ago, and he pretty much hasn’t been back since shortly after that with that userid. Moving on...
Bugatti32
Off road adventures are perfectly stimulating but off road in a lifted Expedition is just SEXY!!!!
schmaltz
jackson wy
2”/2” eBay kit to maintain the rake. I decided to go for it based on this thread.
Tires are 275/75r18 BFG ko2s.
I’ve seen references on this forum to moving the brake line clip, but the instructions I had and the ready lift that downloaded make no mention of moving the brake line clip.
Which line is everyone moving? Front or rear? My rear lines are definitely tight at full droop.
What is the deal with the 2/2 kit vs the ready lift 2/3 kit? Do ya'll recommend the bilstein 4600s too?
3tonsoffun
Personal preference really. I have the 3/2 and 35/11.50/20s on my 16 and love how it looks. However, I’m tuned, and 35s are really heavy. When I need new tires I will most likely ditch the 3/2, go with the new bilstein 5100 adjustables and run a slightly larger tire than the stock 275/55/20s.
My wife has a stock setup with 275/55/20 on 20x9 +10s and the way it sits on stock height is perfect.
5100s for lift, 4600s if your towing
schmaltz
jackson wy
Why would you choose the 3/2 over the 2/2? What does it mean? Are you saying that the 5100s provide he lift but are not good if you want to tow? Do you guys have to re-gear for these larger tires (and reset your speedo) like in the Jeep world?
3tonsoffun
Only way to fit 35s is to get the front up 3” without having to do a ton of cutting. 3” front 2” rear, basically strut spacers. Anything more than that and your suspension angles are all jacked up. The 5100s only offer like 1.6” of lift on their highest setting so if you want a slightly larger tire than stock and a very minor lift, do all four corners with 5100s. I have heard from several f150 owners that if you plan to tow, 4600s will be your best bet. They offer no lift but great ride quality over stock. 5100s you can use to tow with but you may want to keep them at stock height setting. The 3/2 or 2/2 spacers are great and all but there are several options out there nowadays to meet your needs.
As for re-gearing, I’m already running 3.73s with HD tow package and the wheel and tire combo I have are perfect for those. I am tuned so can easily adjust my tire size when uploading a tune to correct the speedo. And yes, usually anything over 33s needs adjustment. I was off by almost 5mph after I put lift and tires on
schmaltz
jackson wy
OK. So the 3/2 will get me the biggest tires. I would like 35 x 12/11. Then I get the 4600s to improve ride quality. Then get the rims and tires? I have a 14 EL that I want to make more offroad capable. I have a lifted Wrangler and I'm just trying to figure out what to tell my mechanic. What does the coil over do for me?
