Weird noise under light acceleration
trunk monkey
Atlanta
2018 max xlt with 4x4, 36,000miles.
I’m hearing a strange sound right at about the 1700-1900 rpm range. As I lightly accelerate I’m hearing (and feeling) a very fast vibrating sound that ends with a light thud...sounds like its coming from the passengers side front wheel area. It doesn’t do it all the time, so I haven’t taken it in yet.
Any ideas or suggestions? Thx
IWE (Integrated Wheel End) or also known as a Vacuum Hub. Could be one of them or the check valve on the firewall. Next time this starts to occur switch to 4A and see if it subsides, if it does you know it’s in the vacuum hub system and can proceed to testing the check valve etc.
Commonly when the check valve fails under acceleration vacuum drops and the hubs partially engage. If a seal is going out on the vacuum hub itself it can do so as well.
3tonsoffun
Could be gearing issue as it’s looking for what gear to jump to, like on a bicycle where if your in between two gears it kinda grinds until it hits the right full gear
aggiegrad05
North Texas
It’s this. There’s a TSB for it. Mine had it as have several others.
Easy fix under warranty.
https://static.nhtsa.gov/odi/tsbs/2020/MC-10171859-0001.pdf
3tonsoffun
The thud he hears makes it sound more like from the gear changing, dont think it’s hub actuators. Hub actuators are a humming noise, I’m thinking gear issue, just my opinion before y’all start hackling me about it since I’ve had and experienced failed IWEs twice now on my 16
aggiegrad05
North Texas
When I had this issue it absolutely sounds like a grinding noise. So much so that I initially thought it was a tranny issue as well. The teeth of the hub rub against each other until they finally seat, hence the grind and thunk.
The system can’t pull a strong enough vacuum to disengage the hub, but it tries. So it half way disengages the hub. But then when all the air leaves the system completely, it engages and that’s the thunk.
I’d bet my paycheck on it. Especially as his is a 2018 (they corrected the problem for 2019+) and this is a well known issue. Whereas a hunting tranny causing grinding is not.
3tonsoffun
Guess only way to find out is to throw it in 4hi and see if it goes away while it’s happening. Switch back to 2hi and if it happens again in 2hi it’s the actuators. Can Forscan measure the vacuum being pulled like a tuning device can?
If it is the 4WD system, I’d definitely start with the solenoid or check valves first. Cheapest and easier fix and probably what Ford will do regardless of their being a TSB until the problem presents itself again
When my 2007 had the vacuum hub issue (it’s been the same basic system since 2004) it at times would grind and clunk so aggressively it felt like I was running over a squirrel on a perfectly flat road. In my case it turned out my passenger side hub seal had cracked and was losing vacuum under acceleration. I’d bet his being an ‘18 is the check valve. Indeed a more common issue but an easy one to resolve.
eatonmom
I have the same issue. I didn't have it before they replaced my transmission due to 4wd problems. Now I have the grind/rubbing noise on shifting mostly from 1st to 2nd and 2nd to 3rd. Does that sound like what you are experiencing as well?
aggiegrad05
North Texas
Given your repair history, THAT may actually be a transmission problem. But I would think having them look at the check valve TSB would be a pretty easy trap to run before tearing into the transmission again. Good luck.
rjdelp7
2000 XLT
NY
Turbo wastegate rattle. There is a TSB for it. You would be experiencing loss of power.
acf83
SAN ANTONIO, TX
Could you point me to this TSB? Mine rattles and the dealer says it’s normal. I do know when they gave me a loaner it ran way better then mine and didn’t rattle
T
trunk monkey
Atlanta
you get to keep your paycheck. They took it for a test drive and were able to re-create the problem. I’m still at the dealership and haven’t driven it yet, but I’m hopeful once the work is done the noise will be gone. Thanks for the help.
