Battery drain
tilliepeople
Madison
I come out every morning to a dead battery .
Battery is only 6 months old and tests good .dropped in a 135 amp alternator .
Is there any fairly common things that go wrong that would drain the battery that fast ?
Thanks
Bill
Hamfisted
Ft Lauderdale
Things that will kill a good battery overnight. Headlights left on, or the rear window wiper motor not able to "park". Since you replaced the alternator. Was the old alternator bad ?
Plati
Yes ... many things can drain a battery overnight ... too many to list.
BUT the only one I had on my 2003 is the rear wiper through the glass bushing being crudded up so the rear wiper doesn't go to the park position. Its happened 3 times I think so right away thats the first thing I think of when my battery drains overnight.
Adieu
SoCal
Overnight or just doing once-a-week 1 mile grocery runs since the corona situation began?
heston gee
Madison, SD
One culprit for a draining battery is the rear wiper.
Ford identified the problem as the rear wiper wanting to return to home and if it is not ot able to the battery will drain. If this is your problem, replacing the rear wiper pivot will fix it. If you dont want to replace, open the lifthate glass and the motor will return to home.
Attached is the TSB from July 2013
Didnt see previous reply on this identification.
  • tsb07-10-13.pdf
CaptainKrunch
washington
Do your draw test as mentioned earlier in the thread. I believe the factory manual states the draw should be between 24 and 26 mah. I find it odd to have such a small differrence between the 2. And this is for a factory vehicle with no after market stuff.
Wegner44
Keep in mind that all 12 volt outlets remain hot while vehicle is off. I know its obvious, but something to check off the troubleshooting list.
rjdelp7
2000 XLT
NY
My CD changer had a jam and kept trying eject.
Old Guy
Central Florida
Instead of chasing your tail, use a digital volt-ohm-ammeter and put it in series between the battery and the + terminal and actually measure the current drawn. My 03 measures about 85 milliamps. If its a lot more, have someone watch it and pull fuses one at a time. When the current goes way down, then troubleshoot the item(s) on that fuse line.
T
tilliepeople
Madison
Yup
Turns out the rear window transmission is bad .
Not able to park.
New one is on the way.
Thanks for the help
Bill
Plati
Yup
Not able to park.
Thanks for the help
Bill
You know its quite straightforward & easy to take that apart, clean it, lubricate it, and put it back together and fix the problem. There are Youtube videos on that if you need some tips.
Of course every vehicle has it's own unique problems and I dont know exactly what the issue is with yours. I myself have had to do that to mine two or 3 times now. Its just a shaft that goes through a bushing that gets crudded up with dirt and the lubrication degrades.
