“Premature” Control Arm Failure with 3/2 ReadyLift?
Mark Buckner
st. Louis
My 2012 EL is in the shop after failing safety inspection due to both Upper Control Arms failing in 26 months. ReadyLift assures me their 3/2 leveling lift should work with factory UCA and the Moogs I put on 2 years ago are direct replacement with same angles, etc.
Does this seem like too soon to need new UCAs? This vehicle gets limited off road use, mainly a week each fall in Colorado, but otherwise is just my daily driver. Pretty pricey to have them replaced due to extra labor required because of lift, so I’d like to avoid this in the future if I can.
Anyone else experience this? Thanks!
Trainmaster
Old School Member
Rockaway Beach, NY
I've had real problems with Moog parts in the last several years. A good number of them have failed within a year for me. It's not the Moog it once was. I'm not surprised they failed. An OEM part might give better service.
07navi
Mt.Shasta California
I heard they took a dive in quality about 10 years ago also.
joethefordguy
yes, far too soon. lift affects the working angles for suspension and drivetrain, and can easily exceed the built in tolerance of OEM suspensions and drive trains, leading to greatly increased wear. any new such components must take into consideration the change in those working angles, or the parts will simply wear out.
Mark Buckner
Mark Buckner
st. Louis
Thanks Trainmaster. The shop doing the work said parts in general have been getting worse and he wasn’t surprised the the Moog part failed.
Aces
Murrieta, CA
or you can go with an aftermarket UCA (icon, baja kits, etc). I run ones from True Travel Dynamic. you can Yes they are pricey but are built well and especially with your lift they are made to handle the it.
07navi
But do you have to realign it and do these Expys have an eccentric camber part in the front upper control arm?
Aces
Murrieta, CA
Yes you will need an alignment after but too my knowledge 3rd gen Expedition share the UCA with the 09+ F-150.
Greg S
San Antonio, TX
I just installed the 3/2 ReadyLift on my truck about 3 weeks ago (replaced all 4 shocks/springs at the same time with the KYB Strut-Plus), and have about 700 miles on it so far. I've got 99K miles on my truck (2016 Expedition EL XLT). The truck aligned just fine after installation. After allowing a couple of weeks for the new springs to settle in, I noticed that the factory UCAs were still pretty well maxed out and I was concerned about the stress it would put on the factory upper ball joints over time, so I replaced my factory UCAs with the Mevotech Tough Terrain TTX which have a zerk fitting on the upper ball joints so I can grease them. Time will tell how long the ball joints will last, but I'm hoping they will last awhile with regular greasing. Also, alignment wasn't an issue after I installed the Mevotechs...caster and camber did not need adjustment as they were within specs, and the toe only needed minor adjustment.
I looked into getting an extended UCA, and couldn't find any for the Expedition but there are several options out there for the F150s. The factory UCA part number for the 2009 - 2017 Expedition is the same as for the 2009 - 2016 F150, so any of the aftermarket UCAs for lifted F150s of those years should fit our Expeditions as well. The only thing to watch out for is the backspacing of the wheels if you're running aftermarket wheels. All of the extended F150 UCAs that I found would only work with wheels that have 5 inches of backspacing or less. My wheels have about 5.5" of backspacing, so I didn't go that route as I was concerned about the extended UCAs hitting the inside of the wheel and tire.
Time will tell how long the Mevotechs will hold up, but I read some good reviews. The UCAs are close to the spring and I would prefer to go with an extended set of UCAs, and may end up going that route if these don't hold up in the long run.
Best of luck.
Mark Buckner
Mark Buckner
st. Louis
Well, here I am back again with the same issue except that it's only 24 months. They may actually be failing earlier because we only have safety inspections every two years in Missouri and that is when they have been caught. Ror right now it's only the right UCA that is shot, but I will replace both of them while it's in the shop anyway. Lifetime warranty "Precision" brand UCA, so I am "just" paying for labor. ReadyLift SWEARS that the 3/2 lift should wok with stock suspension parts, but I am really skeptical at this point.
I am going to plan on having to do this again in another two years (or less) and would appreciate any recommendations on a better UCA. I'll be checking into the True Travel Dynamics and the others mentioned by Aces. There is also a company called Specialty Products out of Colorado that I intend to call. Thanks for your help!
Dustin Gebhardt
Tulsa, OK
I have a full set of the Mevotech Tough Terrain uppers and lowers in the mail via RockAuto. I’ll install them in a week or two. The alignment shop told me that the upper ball joints were toast and the lower arms were unadjustable at the bushing.
oldpaddy
Cape Cod
Good luck. I've had the lifts and bds uca's in since 12/19 with no problems. In fact I had it serviced yesterday and the mechanic says it all looks good. I want to say I had my lca's replaced at the same time as the uca's. The nice thing about the bds uca's is the ball joints can be replaced without replacing the whole arm.
