Front differential fluid change + fill plug upgrade
762mm
Quebec, Canada
So, I decided to do the front diff service today and change the original front diff fluid that's in there before winter (with 132,000 miles). As most of you know, there's no drain plug on the front diff (as opposed to the rear diff, which has one) and the only good method to do this without taking off the front cover is to suck all the fluid out through the fill plug! :eek:
For this, you will need a fluid suction pump. I bought a model which works on compressed air for about $15 on Amazon... and it worked surprisingly well. It came with the wrong coupler though, so I had to swap it for a "Milton type M" right off the hopper. Besides that, I was very pleased with the quality of the tool for the price.
Before beginning the procedure, I drove the truck for a few miles in 4x4 HI, so that the fluid would mix with the gunk/sediment in the diff and also warm up a bit, as it was 50 F outside (10 C). I then jacked up the front wheels and set the frame on 6 ton jackstands, just so the wheels are slightly off the ground and could spin freely, in case the bolts inside the diff were in the wrong position to pass the tube through to the sump and I'd need to spin the front wheels by hand... I actually did have to spin the wheels a bit later on.
The procedure took quite some time (15-20 minutes) and I had to empty the small tank on the tool several times before getting all 1.8 quarts of old fluid out. The old fluid looked and smelled nasty, plus it had a dark grey / gunmetal color to it.
Here are some pics of the procedure. Becasue the fluid was quite cold, the flow was very slow... but still better than taking that pesky front diff cover off, lol :
FordTech Makuloco's instructions video :
762mm
762mm
Quebec, Canada
I also noticed that, unlike the rear diff, the front diff does not have a magnetic fill plug for some odd reason (FoMoCo trying to save 5 cents?). Luckily, I had one on stand by that I also purchased on Amazon for $5 a few weeks ago, as my transfer case has stock fill and drain plugs that are not magnetic either... :mad:
Anyway, I tried the magnetic fill plug in the diff and it fit like a glove... plus just to test it, I ran it in the old fluid and it immediately picked up some small specs of metallic gunk, confirming that it works as intended. :)
Here are some pics of the "upgrade" (I applied some teflon tape on the thread) :
New vs old :
Installed in front diff (using a 17mm, 12-point socket) :
Black
Kentucky
Have a link to the tool at Amazon?
I have a Griots Garage one man pneumatic brake bleeder that works for the job but is even slower than yours since it is designed for thinner brake fluid.
762mm
762mm
Quebec, Canada
The tool I used is very common and if you're willing to wait, you can get a better deal ($10) on eBay, for example. It all comes from China, but the quality is surprisingly good. The cap and mechanism are CNC aluminum, which was a nice surprise... and the tank is a very thick, heavy duty plastic.
It is marketed under different names and different descriptions. Some call it a "brake bleed tool", where others call it a "fluid replacement tool". It works well for any application, though.
If working with diff fluid, in retrospect, I would recommend waiting for hot weather or to warm up the differential casing with a propane torch before extraction, to speed up the process. Similarly, I placed my two 75W90 1-quart bottles of new fluid into a pot full of hot water prior to pumping them back in with my mini manual pump. It made it so much easier! (I didn't do this when filling the rear diff and was pumping for 30 minutes, lol)
Here's the Amazon link:
https://www.amazon.com/Brake-Change...SXV0JBXWPFJ&psc=1&refRID=2J2QJW8JRSXV0JBXWPFJ
dcsang
Great post! I decided to proactively drain and fill transfer case along with front and rear differentials and got stuck here. My wheels were grounded and I had no success with a narrow tube. Is there a method to spinning the wheels to provide the clearance needed to get the tube deep enough into the case?
07navi
Mt.Shasta California
I am always on top of everything on my vehicles to keep everything working like it should but I will never drain my front diff. They spin about 1% of the time and changing the oil will do nothing which is also the reason for the missing magnetic plug........there is nothing to magnetize.:shrug:
dcsang
Perhaps that is why there is no drain plug, and it makes sense. I don't know how the previous owner used the vehicle so for that reason I thought it couldn't hurt to change it. The rear fluid was in surprisingly good condition for 100K+ miles and I'm pretty certain it was never changed. Only the typical accumulation on the magnetic plugs.
07navi
I haven't read the manual on this but my Excursion didn't even take synthetic in the front and the rear went at least 100k miles before a change according to the manual. Your previous owner would have had to spend an awful lot of time off-road and even then the power would have been split in half with the rear plus it was all low speed. In all my years of being a mechanic I have never heard of a front diff wearing out that kept all of it's oil from day one.
dcsang
The 150K miles maintenance schedule calls for transmission fluid and filter, front axle fluid (4WD), rear axle fluid, transfer case fluid, and drive belt(s). I'm not there yet but have seen too many instances where the first fluid flush at a high mileage intervals coincidentally leads to component trouble or failure a short while down the road. I'm not referencing Ford trucks in particular but figure early service of these fluids over 100K miles couldn't do any harm.
A little persistence and wheel rotation provided the necessary clearance for a 5/16" O.D. tube with enough rigidity to avoid bending with minor resistance. I used a manual pump with clear vinyl tubing and 9" of the 5/16" tubing extending from the intake hose. This worked faster and more efficiently than all the videos I've seen utilizing compressed air extractors. I measured darn close to the specified 1.7L. The fluid was the same grey color seen in most of the available videos. Some believe that's due to water penetration and others attribute it to a grey marking compound Ford used on the gears from the factory. Either way, it was noticeably thinner than the 80W-90 replacement.
Now I just need to find a dealership that will change the transmission fluid since my local service departments refuse to do it until the vehicle reaches 150K miles. That's a different topic altogether.
07navi
Why won't they do it with less than 150k ?
dcsang
I'm glad you asked. I called to inquire about the cost of transmission fluid replacement and was asked for my current mileage. I was promptly informed that the dealership would not perform that service until the recommended 150K miles based on the maintenance schedule. I then asked to speak with the service manager, and was informed that I was already speaking with him.
Puzzled? Yeah, me too! My search continues...
07navi
They figure it doesn't need it yet and they might get in trouble for doing it or they are sticking to their recommended values out of principle.:shrug:
coupe11
When I've done that in the past I just bought a new gasket/seal and removed the cover plate. Let the old fluid drain out, clean up the cover plate and differential sealing surfaces, install the new gasket/seal with a bit of gasket sealer (to seal and hold in place) and reinstalled the cover plate before refilling with new fluid.
In my case I had 251,000 miles on my old F150 4WD when I (screwed up and) traded it off.
Slightly different on the Olds 98 and the IROC Z28 as I replaced those rear ends with ones from the junk yard and wanted to inspect the gears and put new oil in them prior to installation.
dcsang
I haven't worked on one of these sealed transmissions before but it looks like the procedure isn't much different. The service manual states that the transmission temp should be about 100°C when checking fluid level. I'll have to check if my OBDII can read that. The process shouldn't be too messy if the fluid is siphoned first so I'm thinking of giving it a shot.
If anyone has any advice please share, but I don't want to further derail the OP's thread.
Ramv36
Last month (Jan 2021) I had my transmission fluid/filter changed at my local dealership on my 2010 Eddie Bauer with 148k miles. Dealer tech's only inquiry was if I knew it was ALSO due at this age for a coolant flush and replace, brake fluid replace, and front and rear diff fluid change. He made a point to say "The differential spins just as much as the transmission, so it's just as much in need of changing". I'll do that myself.
Only took 90 minutes, they had a nice waiting room, and also did the full multipoint check and said everything else is in great condition. Weighing the fact it's winter and I have no lift at home, I think paying them $238 to do it right in less than two hours was a hell of a value.
07navi
Dumb statement by the dealer.
IDK about the value when it was 10 times what you could have done it for.
mnachreiner86
Missouri
Again, you’re being contrary. It’s not a dumb statement. He’s saying it’s working just as much and that’s true. Fluid burns up and breaks down over time. He said it was cold out, didn’t have a lift and felt it was a good deal for his situation. I’m glad he’s happy, I’m glad he shared price and experience for others that may be in a similar situation/need. That’s what this place is for, to help others and share experiences.
ediddily
Nevada
Throwing my $0.02 here on the spinning of the front differential. If your car has the IWD vacuum hub engagers, then your front differential is indeed spinning in 2wd! Dont believe it? Put your car on jacks w/ all 4 tires off the ground, start the car and put it in Drive and watch the design of a constant free spinning front differential waiting for the vacuum to be released and the hubs grab the wheel. The transfer case does not fully disengage the front drivetrain, it only transfers power to the front on the car. Since the front drivetrain is a on-the-fly design, its just waiting for your command to engage the front hubs. That's why when a IWD goes bad you hear the grinding/ticking noise as its trying to partially engage with the CV shaft. Its a bad design in my opinion but manufactures design things so naïve people just take their cars to the dealers for service.
