Update all versions of Ford Sync 3 to the latest Sync 3.4
keny01998
Arkansas
I just upgrade my from 19101 to latest version 20136 using Cyanlab usb. The process took about 40 minutes and everything went smooth. The interface is snappier than my old one.
DWs-TTEB
Evans, GA
I upgraded from sync 3.0 19205 to sync 3.4 20136 w/ maps 19 (NA region) using the cyanlab usb w/o issue. All working great even switching songs loaded on a USB flash-drive. Process took 38 mins.
Super Moderator
Super Moderator
I upgraded from sync 3.0 19205 to sync 3.4 20136 w/ NAV 19 using the cyanlab usb w/o issue. All working great even switching songs loaded on a usb flash drive. Process took 38 mins.
Did you have Nav In Motion(European Locality) set before the update?
DWs-TTEB
Evans, GA
Not that I am aware. I bought my Expy 2 wks ago (Jul 12th) in Nashville, TN. It lives in GA now. The region it had pre/post upgrade = NA. 2>dev/null (bash syntax aka Linux/Unix)
5280tunage
colorado
Same issue for me. Now I can't browse them unless I'm stopped and parked. STUPID.
Highlightreel
MN
Ok, I'm wanting to upgrade from 3.0 19025 to 3.4 20021 before a trip tomorrow. I used the cyanlabs installer and downloaded to the point where the pop up showed telling me to pull out USB and put in car. I put in car and it says it notices the usb but that's it. Never says it's updating.
I had this issue with the NA 18 maps 'free' update but eventually figured it out.
What simple thing am I missing? I had the folders in the usb closed. Then I tried opening SyncMyRide folder and same. Nada.
Thanks in advance!
Stay Classy!
For those that care, I used a different USB stick and it worked. I did do the Loki reboot prior to as well. So today I looked and they updated the cyanlab downloader and removed the version I had 2.1.1.0 and I used 2.1.1.1. Took 28 minutes. Sweet. Seems better so far.
Thanks all!
sharprd65
