07navi
What would you say is the biggest 20" tire size you could use with no lift ?
285 55 20 I thinkWhat would you say is the biggest 20" tire size you could use with no lift ?
Dont know if this will help at all, but I used this website a lot in finding bigger tires for my car.What would you say is the biggest 20" tire size you could use with no lift ?
Easiest thing to doWhat would you say is the biggest 20" tire size you could use with no lift ?
It just showed stock size but thanks.........Dont know if this will help at all, but I used this website a lot in finding bigger tires for my car.
https://tiresize.com/calculator/
I was more interested in changing the 55 figure but thanks............285 55 20 I think
You should be able to compare the stock size to a different size you put in and it will convert it to inches as well, and if you measure for clearence you can apply it to the website. I don't know if it'll work for your situation but it worked well for me.It just showed stock size but thanks.........
Yea, that's what my winter tires are, I think I will stick with that size.Fine, how about 275/60/20
