Leveling Kit Assistance/Suggestions
Robert McMillan
US
What would you say is the biggest 20" tire size you could use with no lift ?
Easiest thing to do
grab a buddy and have him or her sit in the drivers seat, turn the steering wheel to full lock left and right and measure height from top of tire to closest suspension component and also inside and outside tread left and right to closest thing the sides of tire would touch. Using those measurements, you can see how much taller and wider you can go.
R
ral_19
San Diego, CA
It just showed stock size but thanks.........
You should be able to compare the stock size to a different size you put in and it will convert it to inches as well, and if you measure for clearence you can apply it to the website. I don't know if it'll work for your situation but it worked well for me.
steeltoe
brooklyn
Sorry to bump. I'm doing the same, looking at either the Ready Lift 1.5" or the 2/3 lift. The 3" lift sounds extreme but I see a lot of people saying they're happy with it, that it's not too crazy, and the 1.5" isn't worth it. That makes sense but I'm worried about wear and ride quality. Anyone notice long-term issues with stretching cables or wear on the shocks or other parts?
Basically plan on doing just the lift & shock upgrades from this build: https://www.stage3motorsports.com/S...on-5-4L-Builds-Leveling-Kit-Wheels-Tires.html
Any drawbacks I should be thinking about?
