07navi
My new to me '07 Navigator finally approached the 5k mile change time since the seller had just changed it but when I went to remove the pan plug it had sealer around it and I had to get out the breaker bar, and luckily it wasn't stripped. Then the off brand oil filter was on so tight I had to get out my 16" channel lock pliers. After mangling the filter for 20 minutes that finally came off but then the little pan some engineer had bolted to the crossmember to "direct the oil flow" was spilling oil out the front and back at the same time so that thing went in the garbage. Now it's full of synthetic oil with a Motorcraft filter and it will be a breeze next time.
valve do?
