Electric running boards won't go all the way up.
Aspen03
Indianapolis
From your first pic it looked like it was touching the frame. Crappy angle pic? That's on you, should have mentioned it and would have avoided about 65% of this thread.
A gap isnt normal, why it's there is the question. If it's not the hinge and nothing is bent there isnt much else aside from something gearing/motor related. If it works fine you either decide if the gap is acceptable on a 13yr old vehicle or start replacing very pricey components. Having the same running boards as you on our 03 I'd rock the gap, if they quit working I'll find replacements at a yard or just get fixed running boards. Dont really care about the power option myself, its cool, looks nice but in no way worth the $ to me or a potential future owner I'm sure to spend a grand or two for a novelty feature.
Robert McMillan
US
This guy is senile we’ve been trying to deal with here. His truck is almost as old as he is. He won’t listen
07navi
07navi
Mt.Shasta California
On me? I never even noticed it until somebody mistakenly brought it up like all the dirt that wasn't there also. You could eat off these hinges.
07navi
07navi
And you are a naïve little punk..........little Bobby...lol. Neither one of you guys can figure out what the problem is so you just hurl rude remarks. Really immature.
Done with this thread, I figured nobody knew the answer but didn't expect anyone to make it look like it was my fault. Y'all ain't growed :shrug:
If you guys don't know the answer don't say anything, you don't have to get rude and come up with obvious stuff I already know about. I just thought maybe it was an easy fix that I wasn't aware of.
Robert McMillan
US
The fix isn’t worth doing on a 13 year old truck. Is the motor/mechanism that is failing. Soon the gap will grow until one day the birds hang in the open position permanently. That gear box is 13 years old. Couple grand will fix it but is your truck even worth a couple grand?
Jamo
Lee Center, NY
Did you lift the truck one inch? Either you didn't adjust the boards to make up for the lift, or you didn't get the 1" board lift kit when you did the truck lift? Nobody thought of that...
07navi
07navi
:emotions33:
07navi
07navi
So there is an adjustment? The hinges fold flat so it's not the motors and they are both exactly the same front to back..........very strange and challenging. Again, they work perfectly and come to a hard stop but won't close the gap.
turtle019
MI
Wow this thread went off the rails. Play nice guys. We're all here to have fun and help each other out. I know you're both very knowledgeable and helpful, but this.... this is bad...
I'd say a bit of a gap is normal. Yours might be bigger than mine, but mine certainly isn't flush either.
wemWNKd7bFo2Y5JTzIWftyNBF16tzP3yyUmxXswSZs2PUDmu_cKk_dLBIlbaDLdyI-yqcPOddS5P1Z8ZhXax4fXHH_rMPDw-S26ud0tGMx4E1v7BbnlQXF-00pXuT7jpN0AMfeTyre_aDglPehgNSyXbo1i95lsTEFyK0JkDgVph3xOBXfTp_lVXIz-aL87qY7tUDnQo8OHOPUA2kSg6QdUtF1Lor34r-_DqLBpIrFPhtxT_9d7rVDgc-sS_Sv1nsTyrZteC89VMBl-FAgi4x2qe3cqbcrHn2zpSU19pXuyMqL25DZyhQuemiQ9AsDf2w7pJZaoURB_MvK_Bk8DEAcB3iglvJOQ8Fvys-WP-PH7TfV3c7lkhisl4RnOt70kmWHW7bhNCuJVrdOck-1CWAoaOGb4ynpIx7tp4PhWv73oBG8LSlTfEKpA-QJNc0FbpRcvY_HZpBKfU2HHNQfkC4LiSLJ0ezZUNSXtvb4dcgb0i23kXUp8tH_B_XZGe7twpCuQzCaEEE446toXfU4CL3mMCdzk7ScnkYKcg9JF6K0i4vfE1-ceZ3CBFxSViCp8FBT4nfWdnelh6BapKtP-bwVBv8yE0g2iMrkjhNzmrvw0NDBKUTt_IwP5KlFvzr15VV8xx2--cxLCpLjMPlU5THdt-wJ9AloiZjqrIZkzkRrcoZuO5CsQXMBVTkmH95Q=w538-h954-no
07navi
07navi
Wow it looks like mine. When I get time I am going to look deeper into it and report the findings if any.
Jamo
Lee Center, NY
I was kidding, '07. I've got a bit of a gap too, when they retract. I have a huge gap when they don't...big enough to put your feet on. Pass side works great, driver's side, not so much. Very intermittent...
Flexpedition
midwest
There is a easy limit relearn procedure but have never had power boards to say if its effective.
Key switched on but engine not running for older models. For newer models double tap push button start but don't touch the brake pedal. Doors unlocked.
Open a door to extend. Stand on or apply some downward force to the board. You or someone else close the door completely. Board should remain fully extended due to obstacle detection, similar to the safety feature of power windows. Step off or remove force. Open then close the same door.
The board should, key word being should, retract fully. Do the same on each side. Its possible the board(s) had a mud or snow/ice buildup at some point and the motor learned a new, incorrect stopping point.
07navi
07navi
Anything could have happened before I bought it a 138k miles but I will try fiddling with relearn procedures. The hinges appear to be folding flat which is throwing me a curve. I will post back on the findings. Some say don't worry about it but it's in mint condition and the only thing wrong with the whole truck.
07navi
07navi
Nope the computer didn't learn anything but thanks anyway.
07navi
07navi
I'm like Trump I punch back........but I don't start anything.
