When You Lift an Expy...
Expedition Dave
A Tiny Little Dot in Florida
When you lift an Expy either through 5100s or coil spacers, how much do the wheels tuck in? I have seen where they get close to the forward part of the rear fender, and generally I am not concerned since I am going with a 1.5 inch lift all around--but was curious about the "tuck" and if anyone had measured it.
Sunflowergirl
Mars
It’ll look like a dude who never does leg day at the gym with stock tire size. I did the ReadyLift 3/2 on my 2016 EL and I absolutely hated how the tires looked bc you could look down the side of the truck and not see one part of the tire with how far they got pulled in. I went and put 35/11.50/20s on stock wheels and they still just barely stuck out as far as the ones did prior to lifting it. So I put 1.25” spacers on the wheels and they are perfect now!
Sunflowergirl
Mars
Best before with lift and stock tires and after w it h 35s and spacers on wheels.
Expedition Dave
Expedition Dave
Thank you for the pics! I wish more people would post more pics (it is very easy) as it says 1,000 words! Personally I do not like tire poke, and since my truck comes with 32s I planned on adding 33s of similar width, on the same rim and was concerned how far that minor of a lift will pull it in. I used to have a HD jack, but no more. I do not want to look lifted, but subtley raised--the way these 4x4 should have come factory.
Sunflowergirl
Mars
You will probably get the look you want with 33x11.50s. Let me look for a pic of before and after wheel spacers and my 3/2
Sunflowergirl
Mars
Here you go, this is Readylift 3/2 with 35/11.50/20 stock wheel NO WHEEL SPACERS!
CAD5808B-E394-4F20-890B-8E06AFB62E4E.png 641A5FEA-D945-417D-83CD-A6AC618940F9.png
Fozzy
Riverton
I don’t have a really good pic, but your question about it moving the rear tires forward into the rear fenders. It does make it look that way. Especially with large tires. Anything bigger than a 35 will probably stay stuck in the rear fender well on full compression.
Jeremy Harnit
So cal
Any put a level kit on a platinum with the ride control system. All the manufacturers say not to do it.
Sunflowergirl
Mars
Yeah it’s pretty noticeable moving the tires forward when we lift
Big H
New Jersey
Yup, I have the CCD and used this kit. Had my dealer install it as well. According the ready lift, I was the first one to install with the CCD brackets. All they really do is push out the reach on the dampening control units for the front shocks. But it’s needed in order to clear, and Ford can’t do proper alignment either; will have to take to independent shop to adjust to the specs readylift gives for the kit.
Fozzy
Riverton
So no rear relocation or sensor adjustment? Post a pic of the bracket installed. Curious on what it does and why nothing in the rear. There has been many debates about these sensors. Thanks.
Big H
New Jersey
No rear location change required. Only for fronts.
Here are pics: rear is first, then front left and last front right
Fozzy
Riverton
Wow, your underside is super clean. Thanks for the pics.
Big H
New Jersey
Thx [mention]Fozzy [/mention] I just had it coated with the military Tectile spray. They use this stuff on the military rigs to prevent rust and rock chips and other undercarriage issues. I live in the northeast so road salt and weather changes really take a toll on exposed metals.
Lou Hamilton
Do you have pics of the full side?
Also what tires did you put on it?
Big H
New Jersey
Here are pics from the side Lou. Haven’t switched the wheels yet, still debating to run stock rims on A/T wheels (Tokyo Open Country III 33”) or do 20” rims on 35” tires.
[mention]Lou Hamilton [/mention]d0ed3726610d97e7d62e62cd88c40771.jpg
Fozzy
Riverton
What mud flaps are those? You will probably loose the front with aftermarket offset wheels and wider tires.
Big H
New Jersey
[mention]Fozzy [/mention] they r weather tech mud flaps. I’ll do spacers as well; maybe 1” front and 1.25” rear if I stay on stock wheels.
May go up to -19 if I do custom setup on American Force wheels or Forgiato.
