Is this a fuse, need some help please.
brilis
NJ
Morning guys,
My 2004 EB with a 5.4 was running perfect until this AM. I don't use the truck too much so it sits a week or so most of the time.
Got in this AM, started it up, started perfectly and was idling perfect. Then I noticed;
No dashboard lights, no radio, no interior lights, I also believe no head or taillights. I don't think there is a fuse for all of those. I didn't have time to look so locked it back up and jumped into my 97 Expy and went on my way.
Just wanted to know where to start looking? Thanks!!
Brian
B
brilis
NJ
Could it be possible the radio, dome, dash are all on one fuse?
Yupster Dog
Moderator
Something you should check is a common occurrence fuse block melt down on the 2nd gen's.
B
brilis
NJ
I will put the cover off tonight. Do you know if 1 fuse would control those accessories? Thanks.
B
brilis
NJ
Came home too late last night but pulled cover and poked in with my flashlight. I don't see any type of melt down so that is good. Too dark to start checking fuses so I will wait. I really don't see one fuse that does radio, dash and dome lights.
Anthony DeVor
What it actually would be is a big fuse powering multiple circuits on the inside fuse panel from the engine bay fuse panel. Our 1999 Lincoln town car is like that, throughout about probably 6 maxi fuses from the engine bay they feed the 30 some fuses on the interior panel. SO check your manual and see if there is a big (30amp +) fuse that feeds the interior circuits.
