Issue after hard rains
Expy730
I'm new to the forum and hoping someone can help with an issue I'm having with my 2016 Expy Limited that I recently purchased. I've noticed that the driver's side seatbelt is wet after heavy rains. I also noticed one that the front corner of the sunroof on the driver's side dripped once but hasn't done it since. In addition; I drained a lot of water from the driver's side rear door once since I purchased. The wired thing is that I can't find water inside the truck with the exception of some droplets around and on the plastic that covers the frame part where the seatbelt retracts
Where should I start investigating? Is there a common problem that could cause this water to be getting inside the area where the seatbelt pulls from? Any help will be greatly appreciated!
Do a search on the forum regarding leaking or clogged sunroof drains and take some time to read the posts. You’ll find your answer.
