Tree sap removal
Highlightreel
MN
I got some tree sap on my vehicle while parking it in the woods this fall. What is a good method to get it off of my paint? There are a couple spots where it has about a 2" drip on the paint. I have been too nervous to scratch my paint, even using my fingernails, since my vehicle has some scratches on it from I do not know when and they are in spots I'd have noticed if I did it so I'm trying to be super careful. I realize it's not good to even have left it on this long but now is the time.
Is rubbing alcohol the solution? I didn't even want to try that but any info would be much appreciated.
Thanks in advance!
caplanm
Boston
There are special tar and tree sap removers out there that work well. Try any auto parts store. You should take care of the tree sap, especially from Pines right away. Letting it sit will cause it to etch the clearcoart
Big H
New Jersey
Hand sanitizer works as well, if u have extra to spare these days. U will need to wipe down more than once to get completely off, as it dilutes the sap.
StealthyBulldog
Manitoba Canada
Also keep in mind that if you use the Bug and Tar remover (and probably any other heavy cleaner actually) once you get it all off, wash it with regular soap and water just to be sure none of the chemical is left on.
carymccarr
Earth
Thanks in advance!
Acetone.
5280tunage
colorado
Not sure on acetone, that will remove any wax or protection on the paint too, but yes it will get sap off. Acetone is rough... One of the least damaging I've used is olive oil, but I recently got a bottle of commercial goo gone (walmart had It in the paint section) to get tar off of my wife's car. It worked quite well and I just used a microfiber cloth to get any residual goo gone off.
carymccarr
Earth
Yeah I’ve had to use it once when there was dried on sap and another time when some superglue dripped on the paint. Tried goo gone first but neither budged.
You’re right though. Gotta be careful (I used a qtip) but it will work 100%. Just need to carefully apply and the wash off immediately.
Fozzy
Riverton
Spray it with WD-40 then soak a rag with WD-40. Hold the tag over the sap to soften it up. Wipe off, wash, clay bar and seal your paint. Then it’s not as bad the next time.
Bow512
TX
My old truck got covered on the whole side with little speckled tree sap and left a rough finish.
Used a clay bar on it and got it all off and was smooth as glass afterwards. Just have to make sure to put some wax on afterwards.
Going_Going_Gone
Phoenix
Just like N95 face masks, rubbing alcohol has become scarce lately. I haven't seen it in the stores I've visited in months.
Don K9SARK
Kansas
I have been using liquid fabric softener for years. Weather permitting, I spray down the front of my vehicle the night before, the wash it the next day. It is not a 100% removal solution, but it softens up sap, bug splatters, and road tar, making them a lot easier to remove. I've never had a problem with this on paint or trim in over 20 years.
Bunky
roy utah
WD-40 guaranteed to work and won't harm the paint. I wouldn't trust Gary Hanna's turpentine idea, though.
5280tunage
colorado
Interesting approach, I've never heard of this. Thanks for sharing.
BlueStangGT
Oklahoma
Clay bar is the right way to do it if you have time to do it correctly. Regardless of method you’ll definitely need to seal the finish when you’re done since all of these methods will leave your clear coat wide open.
Highlightreel
Highlightreel
MN
Thanks all. I tried rubbing alcohol and it quickly did the work. I will get it sealed asap as well as winter is here to stay Minnesota.
