Freaking Catalytic Converters stolen!!
kountrykeith
Las Vegas, Nevada
Don't know if this is the right place for this post so please forgive if not.
While re installing the fuel tank after cleaning it and installing new pump I just happened to notice something different. Both cats cut off with a Sawzall. Gone overnight. Man this is a tough blow. The funny thing is we looked at 2 other SUVs before buying this 97 EB that had been robbed of theirs. So I am wondering if anyone has a low cost solution to replace and then protect them. I was thinking of mounting some stainless wire mesh or the like underneath but they would probably cut through that too. The clamps they sell are out of my reach with this happening. So any thoughts would be appreciated. Thank you.
Your comprehensive vehicle insurance coverage will cover the loss, minus your deductible (parts and labor).
PS - For many years, my wife and I, and another couple, would vacation in Las Vegas once or twice a year. Although we stayed on the strip, we often rented a vehicle and went sightseeing to the various State and Federal parks. The pandemic changed that.
Janky
Seattle, WA
So sorry to hear it. I've heard reports of this happening to a few Toyota Prius' in our neck of the woods in North Seattle. I'm a little nervous since our 2nd car is a Prius. It's especially amazing they could even get under the prius to cut them out - that car is so low I have to drive up on blocks just to change the oil! In relation, the Expy cats are probably and easy job.
coupe11
That kind of damage/theft was a pretty regular thing in parts of Richmond, Va and surrounding areas several years ago.
No matter what anyone says, the last few years of economic growth/job growth has resulted in a lot less of that.
I'm afraid, once the new administrations policies have kicked in the crime rate will go back up as even more jobs are lost/thrown away by ill conceived policies.
CaptOchs
Rochester NY
First things about replacing CATs I found, there are two types out there CARB and Federal Standard. The CARB is required for California emissions. Some states like NY technically required to reinstall CARB if your car came with CARB. Inspection stations generally don't read the numbers to fail you though. I have always installed Federal because for the most part it's much cheaper. If your tag is correct and you're in Vegas, you should be OK to install cheaper Federal CATs.
I have replaced my entire exhaust on my Expy from Walker. You can go with a universal Federal or you can opt for a direct fit. I think I was quoted over $1200-$1400 to replace exhaust on my 2003. I looked up all the parts and ordered them off Amazon or Ebay (whichever was cheapest.) In the end, I only spent like $700 for all the parts I needed When I had everything I took to an auto shop to install. That was everything from the cats to the tail-pipe.
Hope this helps.
https://www.walkerexhaust.com/find-my-part.html
kountrykeith
kountrykeith
Las Vegas, Nevada
Thank you to everybody who responded. I have decided to go straight pipe back to the muffler, forgoing cats for now. Will register in state nearby that does not require emissions. To answer a few questions that have popped up in this thread: Isn't insured, yes its a bad neighborhood, trying to move, that's what the vehicle was bought for, and I can't afford the 1000 to replace them. Again thanks everybody.
CaptOchs
Rochester NY
A Walker system lasts 2 - 3 years, according to their own website.
You gets what yous pays for.
https://www.walkerexhaust.com/support/exhaust-101/why-exhaust-systems-wear-out.html
Keep reading. That's aftermarket exhaust that doesn't meet OEM specs. Walker does. My Walker exhaust has been installed for 5 years in WNY where winter salt eats just about everything. So far the exhaust is holding up. Now there certainly are better exhaust systems out there, but for a 17 year old vehicle this fits the bill.
Thunderbirdsport
Missouri
Lots'o internet statements saying walker stuff isn't famous for their longevity...just sayin'. Maybe you got a good set, or just spend the time washing stuff in the winter to keep it from getting salt eaten.. ;)
Trainmaster
Old School Member
Rockaway Beach, NY
I used to love Walker stuff. Made in Pennsylvania, always fit right, readily available with good catalog pictures. Then I noticed I was buying a lot of their stuff. Over and over again. So I called them. That's when they said it had a life of 2 - 3 years, and that it's "very inexpensive".
I guess some of their things are better than others. Roll the dice.
CaptOchs
Rochester NY
I can't speak for other's "internet statements," so I'll limit my reply to my own personal experience. I feel this has been a suitable low-cost replacement. The pipe isn't thin... chain-link fence quality pipe. The two CAT pipes I ordered came WITHOUT a box. Let me repeat that for impact. It came WITHOUT A FREAKING BOX! LOL! The label was literally printed and stuck right to the cat. So it went through the entire shipping chain UNBOXED and NOTHING was bent. Another pipe section punched through a box corner too. I wasn't pleased with those sellers, but despite little to no protection everything arrived undamaged.
The only obvious differences off the bat was the original exhaust had mandrel bends and the Walker exhaust was wrinkle/compression bends. It's been installed for years and doesn't show any signs of rust. The truck is a 17 old truck so washing it hasn't been a priority. It doesn't rattle or seem to impact performance. My camper is 7000 lbs. empty and it still tows the same.
So that's it. You can spend +$1500 for exhaust on a vehicle that might be worth between $2000 - $3000, or you can go the cheaper route and buy the $700 exhaust. Attached is parts pricing that I came up during my search for my 2003, in case anyone is interested.
