May I ask why a 6.2 over the new 7.3 gasser?
Either way, very interesting!
The 7.3 is a pushrod engine. Without those cams sitting up top it's really compact. One amusing quote I read was:7.3 is no bigger externally than any other modular engine, and will bolt to any trans with the modular bell bolt pattern. It ain't cheap though, there's already guys with them in Mustangs and trucks (swapped in, NOT new Super Duty trucks..)
If i were to do an engine swap to mine, it's be the 7.3 gas. Though the 6.2 sounds good, as well.
$3700 for an engine with all the accessories, wiring harness, pcm, intake... It was a lift out from a 2017 f250 with 50000 miles on it. I'm guessing another 1000 will need to be invested in the electronics. I'm going to do pretty much all of the work.Is this a crate motor? What does one of those cost? How much more have you budgeted to get it installed and running?
