G
Guest
Ok, I am going to sound like a idiot here. I need some info.
I replaced about 90% of the steering and suspension components on my Truck.
All new Eurethane bushings (yes, upper and lower control arms)
New Ball joints
New shocks, Rancho 9 position with cockpit control
Steering stabilizer Rancho
all new tie rod ends
new pitman arm
new idler arm
New steering box.
The box was replaced because the aluminum cover at the top of the steering box was cracked during the removal of the pitman arm.
Now, the steering is very precise, and has absolutely no play, but it is too easy to turn. To put it in simple turns, the power steering has too much power! It makes the truck anoying to drive at highway speeds.
How does Fords Speed Sensitive steering work on the Expedition? Is it a function of the steering box, and the box I got does not have this feature? Is it an adjustment I can make on this to lessen the power assist?
Has anyone done such work on their truck, and what results did you have?
Thanks for any help which can be provided!
Vincent
1997 Expedition 4x4 5.4
New Ball joints
new pitman arm
new idler arm
New steering box.
Vincent
