Misfire and spark plug recommendations.
Melbourne, Fl
I recently picked up an 08 Eddie Bauer with 132k on the clock. Immaculate interior for 4K. Engine has a misfire on cylinder 8, causes the stutter/ hesitation or if I punch it a flashing CEL. Hoping it’s the plugs and coil boots rather than timing, but will do that if necessary. What plugs does everyone recommend? I have seen some people using the updated motorcraft plugs.
Thunderbirdsport
Missouri
Plugs, and if still an issue, swap coils till you find the problematic one(s). Mine did this too, I threw on new plugs and no more issues. I used the Sp509, though mine is an '11....
Trainmaster
Old School Member
Rockaway Beach, NY
Ford Motorcraft plugs. The 2008's with engine dates on the right valve cover built on or after 10/9/07 do not have the problematic "two-piece" sparkplugs.
B
Melbourne, Fl
Just looked a little bit ago. Assuming it’s the printed label on the drivers side valve cover it looks like 11/27/07.
10Expedition
Pennsylvania
You could be describing my 2010 Expedition. Same miss and same CEL. Took it to the dealer because my local mechanic wasn't sure he could fix it. They first changed the camshaft timing control solenoid valves. Didn't fix it even though the computer said they were defective. Changed the coil on the #8 cylinder and all spark plugs and is now running perfect.
Dustin Gebhardt
Tulsa, OK
Plugs are an "easy" solution. Getting at the rear plugs (4 and 8) can be a chore, but not impossible.
Thunderbirdsport
Missouri
Hopefully they only got you for the coil and plugs? Misfire are almost always bad plugs, then coils.
The other stuff is a lot less likely to cause misfires, if at all.
