Ok, what is the problem? Oil build up, rusty lines?
Well, I'm guessing the plugless hole in what I'm guessing is the transmission and the open line in the top of the picture are not normal.
Look and see if that hose/pipe is coming off the firewall, like the evaporator drain line. I don't think it's your transmission fill pipe, but you can look at that too. The bell housing dust cap is not critical but you can replace it if you can find one.
It looks like I'm leaking fluid, that's why I'm concerned.
The only fluid other than water might be ATF for the tranny. How's your ATF dipstick look ? Normally the end of the dipstick would be sticking out there if it was supposed to be tucked into the trans pan. But honestly the whole area looks like a hot mess of leaked oil and grime. Find the other end of the tube and see what you have.
Can someone give me a heads up as to what I'm in for?
The plug missing could also be a sign of torque converter problems. I would defiantly get it checked. That would also be why there is transmission fluid everywhere.
Have you checked the Transmission fluid level?
If the fluid level gets low you will be replacing more than just the torque converter.
