www.tunedbyzfgracing.com
thanks loki - just the person i was looking for a reply from. i’ll take this as the best choice.These are the best option for the 2nd Gen 3.5...
Set of 6 NGK LTR7BHX (95605) Spark Plug | ZFG RACING LLC
NGK Ruthenium HX is designed for newer engines which demand high ignitability. Projected Square Platinum Electrode (PSPE) design promotes spark energy concentration and ignites a wider range of air-fuel ratios, offering improved performance in rich or lean engine conditions. 0.4mm Ruthenium...www.tunedbyzfgracing.com
If stock do .031 Gap, if tuned, .028 is a good starting point. They will come gapped.
How many miles?thanks loki - just the person i was looking for a reply from. i’ll take this as the best choice.
anything aside from boots (pen) that i should also do at the same time?
43kHow many miles?
I just received these exact ones from Rockauto.com on Wednesday. About $8 each. After installing them, I think it resolved an issue of occasional shudder while idling. I will give it another week of driving to determine for sure.These are the best option for the 2nd Gen 3.5...
Yep! Advantage of getting them through ZFG, is they are gapped to exactly what they need to be. Little piece of mind. The gap is just as important as the plug itself.I just received these exact ones from Rockauto.com on Wednesday. About $8 each. After installing them, I think it resolved an issue of occasional shudder while idling. I will give it another week of driving to determine for sure.
I just got them installed gapped from ZFG @. 028. They're awesome.Yep! Advantage of getting them through ZFG, is they are gapped to exactly what they need to be. Little piece of mind. The gap is just as important as the plug itself.
so NGK website says that plug not compatible with 2019 expy platinum. says
LTR6BHX
any idea what the difference is?
They would be wrong. That was explained earlier in this thread. 0.031 if staying stock, 0.028 is what most tuners are recommending for normal tuning.so NGK website says that plug not compatible with 2019 expy platinum. says
LTR6BHX
Do not remove or install plugs on a hot or cold soaked engine, ensure the engine is just warm before replacing the plugs. Torque to 133 lb.in (15Nm). Inspect the boots for dry rot and cracking, if they are still pliable they are good to be reused.Hello, I know this is an old thread, but what is the torque spec for 2023 Expedition Max LTD for plugs? And at about 62k miles, should I replace anything else, such as the boots?
