best plugs in Gen4?
lv2drive
PA, USA
about to replace plugs / for those of you who’ve done this on the gen4’s -
what’s your preference of plug in this beast?
and aside from the boots, what else should i replace during -
thx
Moderator
These are the best option for the 2nd Gen 3.5...
If stock do .031 Gap, if tuned, .028 is a good starting point. They will come gapped.
lv2drive
lv2drive
PA, USA
thanks loki - just the person i was looking for a reply from. i’ll take this as the best choice.
anything aside from boots (oem) that i should also do at the same time?
5280tunage
colorado
I'm kind of curious why you would even do boots at 43k. Over the last 20 yrs I've only done wires if I upgraded the ignition, had some sort of external issue (water etc) or if they were super crappy wires. But most of my previous vehicles all had coils/boots as single units. Honestly haven't even looked at these yet.
lv2drive
lv2drive
PA, USA
read on some thread here about the recommendation on the boots /// sounded convincing enough for me -
wakeboarder
Fort Lauderdale, FL
I just received these exact ones from Rockauto.com on Wednesday. About $8 each. After installing them, I think it resolved an issue of occasional shudder while idling. I will give it another week of driving to determine for sure.
Moderator
Yep! Advantage of getting them through ZFG, is they are gapped to exactly what they need to be. Little piece of mind. The gap is just as important as the plug itself.
Nate2020KR
Athens, GA
I just got them installed gapped from ZFG @. 028. They're awesome.
andyak
houston, texas
so NGK website says that plug not compatible with 2019 expy platinum. says
LTR6BHX​
any idea what the difference is?
TheDoug
Mansfield, TX
LTR6BHX​
The plug recommended by Loki is one step colder. I installed them and I am tuned... use .028 gap and runs like champ.
Phil1919
Atlanta, GA
Hello, I know this is an old thread, but what is the torque spec for 2023 Expedition Max LTD for plugs? And at about 62k miles, should I replace anything else, such as the boots?
apex96
Do not remove or install plugs on a hot or cold soaked engine, ensure the engine is just warm before replacing the plugs. Torque to 133 lb.in (15Nm). Inspect the boots for dry rot and cracking, if they are still pliable they are good to be reused.
