Random engine shutoff
04EddyExpy
Columbus, OH
So my 2004 EB has been giving me some grief for several months.
Doesn't matter what I'm doing, or whether I'm sitting still or driving at any speed -- the engine will just shut off. Sometimes it sputters first, like it's not getting gas, but usually it just flat-out dies. The ONLY way to get the engine to restart is to turn the key off, take it out, open the door (to turn off radio, etc), close the door, and only THEN can I turn the engine back on. Otherwise, it just sits there and tries to start without success.
This happens maybe once every 2-3 weeks. As you can imagine, it's scary as hell when it happens while driving 60mph+. I lose power steering and have to pull over as quick as I can.
My longtime mechanic had the truck for 3 weeks -- ran the engine at idle most of the day with a diagnostic machine on it, drove it 80+ miles... it never happened to them. I picked it up and went to lunch, it died at the restaurant.
The fuel pump and fuel regulator have both been replaced. Problem persists.
The new fuel pump has been checked over. Problem persists.
It throws no codes nor check engine light, etc.
I recently accepted a job about 10 miles away and 3/4 of the trip is on the highway. I can't trust this truck on the highway, so I have to go on side streets which nearly doubles my travel time. Road trips are out of the question, pretty much.
Hit me with your questions - maybe we can figure this out?? Otherwise I have to sell it. Can't afford to throw more money at it hoping to solve the problem at this point.
Trainmaster
Old School Member
Rockaway Beach, NY
I would remove each plug on the computer and check for corrosion. I'd also do the same with the fuse block on the kick panel, checking for evidence of water and leaks. Then I'd switch the fuel pump relay with another. I'd also look at the battery and main ground terminals.
Try juggling the key in the ignition switch and look for some adverse result.
That's where I'd start.
Hamfisted
Ft Lauderdale
Yes, check the harness there at the computer on the firewall, and check the PCM relay in the upper right corner of the fusebox for any melted plastic around the terminals. If it's the original fusebox, the '03-'04 years had a problem with the fuel pump micro relay on the fusebox circuit board melting. In it's early stages of failure you will get these random shutoffs of the fuel pump, which of course kills the engine, with no codes. Have to replace the fusebox with a new one, or have the fusebox repaired (eBay).
04EddyExpy
04EddyExpy
Columbus, OH
Well that certainly doesn't sound fun (or cheap), but this seems to address every issue I've had. Thanks to you and Trainmaster both -- I'll have to get in there and check the relay & fuse box.
BROKENPILOT
TEXAS
Do all the instrument panel instruments, lights, etc... go to zero/off when this issue occurs?
GM had massive problems with their ignition switches - and many of the problems were caused by people having numerous things on their key ring, which caused excessive wear on the ignition switch cylinder over time due to excessive weight.
Does the OP carry numerous items on their key ring (or did the prior owners)? When the mechanic tested the vehicle, did they only use the vehicle’s keys and not the “full” key ring which may have more weight?
The concept that the problem lies in the key cylinder causing the shut off, or an issue with the battery and/or its connectors and wiring, is a good one.
WildBlueYonder
Haverhill, MA
I had an issue on my '05 where I needed to replace the fuel control module. It is located near the left rear tire and is prone to corrosion. It is a quick and cheap fix. I did it myself in my driveway. Good luck
riphip
Memphis, TN.
FCM came out in 2005 & is not on the 2004 models. Sounds like on board fuel relay as Hamfisted stated. Been thru this myself.
rich6655
Milan, Michigan
I have a 2003 Expedition. Same thing happened, numerous times. After numerous attempted fixes I found out that the coil over plugs were bad. I figured 1 or 2 were bad but didn’t want to fix those only to have others go bad. I replaced them all. No more problems. Coils are about $70 each.
BlackCoffee
SOMD
I had similar symptoms before the fuel pump went. Opening the door de-energizes the relay next to the fuel pump real. It may be the fuel pump relay going bad or heat related from corrosion in that area. It could be pump or relay. If it you have a fuel pressure gauge, you an it happens again, hook it up to the Schrader valve on the fuel rail. If it is zero, there is a good chance it is the pump. You might also monitor the pump for pressure when it is working. I have seen them read low or too high before failure.
Fordguy32
San Antonio
If 04 is same as 03 as far as fuse panels I can almost guarantee your problem is in the circuit board attached to the back of the fuse panel behind passenger side kick panel. You will need to remove the whole fuse panel and disassemble (make sure to take pics while you do to remember where fuses and other things go). You will find a circuit board with 4 micro relays in a row soldered to the board. You will probably find one of the micro relays has a melted spot on its side. That’s your problem. New relay is cheap and I took mine to a electronic repair and paid $35 to get it soldered. If your good at soldering you can DIY. One thing to remember though is that some (or all, I can’t remember) of the soldered connections require a connection to the circuitry on both sides of the board. If one is not made it will not work correctly. I have pics somewhere if you want them. Haven’t had a problem since
Holochron
Phoenix
I had the same prob with my 2003 5.4 eb. It turned out to be loose corroded battery cables. (I think. It may just have not had time to happen again because of what happened next) Later after leaving it to sit for a week it had a no crank, no click issue. I was told by my father-in-law who is a mechanic, and by Scotty Kilmer on his forum that it was likely my ignition switch. I really didn't want to have to mess with that. Long story short I did a continuity test on every fuse they were all good. Then I started pulling all the relays from the fuse box to see if any were corroded or bad. The first one I came to was the PCM Relay R203 which the manual says controls fuse 32,33,and 34, Fuel pump relay , Fuel Pump, PCM solenoids and sensors. It is a less than $5 part at the ford dealership near me. I heard a fuel pump that is going out could cause the relay to overheat so I bought a few extra relays just incase. My theory is that the relay was going bad causing the truck to shut off randomly.
