CecilTheMagician
It’s super annoying when I’m backing a boat or trailer and that noise is constant.
Uhh no I didn’t read the owners manualDid you read your vehicle owner’s manual?
On my 2015, I can temporarily disable the front or rear sensors (when they activate) by pushing a button on the steering wheel controls - based upon the DIC display message.
Ah, I couldn't remember for sure if you had to have the Expy running. I know you need it running when you disconnect or it'll keep thinking the trailer is hooked up.You might have something wrong with your trailer wiring. Even if you don't plug in the trailer when the Expy is running. Upon start up it will find the trailer and go through the warning OK's.
How do I configure the trailer length? I do not find that capability on my 2017 KR.Also, if you hook up the trailer lights with the ignition on the Expy will automatically disable the parking sensors and extend the blind spot monitor (if you have the trailer length configured).
That doesn't work on mine. I always have to select "no active trailer".I know you need it running when you disconnect or it'll keep thinking the trailer is hooked up.
Do you have a really small trailer with only a couple lights or no electric brakes? Mine will not work on a little 12' trailer with only the rear lights and no brakes. All my other trailers will register connected and disconnected. I was told to make sure there is a good ground from the trailer to the plug. I have never gotten around to checking the plug wiring.That doesn't work on mine. I always have to select "no active trailer".
It doesn't work on my small kayak trailer or my 25' Airstream!Do you have a really small trailer with only a couple lights or no electric brakes? Mine will not work on a little 12' trailer with only the rear lights and no brakes. All my other trailers will register connected and disconnected. I was told to make sure there is a good ground from the trailer to the plug. I have never gotten around to checking the plug wiring.
Wrong forum - this is the 4th genHow do I configure the trailer length? I do not find that capability on my 2017 KR.
Do both of these use LED lights? Maybe there isn’t a high enough current draw to register the trailer is attached.It doesn't work on my small kayak trailer or my 25' Airstream!
