Sway Bar
Jacob Taylor
Arizona
Had some very interesting feels with the rear sway bar off. Did notice last weekend that we did break traction on something we usually would've. But we have a ton of weight in the back so going to put the rear sway bar back on and take the front off to see what that does for offroading.
Deadman
Good lord, wear a helmet as your head slams into the side windows and it bobbleheads you to death! I'd consider a neck brace if you go over 5 mph. These suspensions are so soft especially in the rear that they must hate having the bar removed once you get some speed up.
dlcorbett
Air Force
tx
His truck doesn't have ccd so he wouldn't have the sway issue. He probably took the bars off for more articulation.
Fozzy
Riverton
Taking the front off helps a ton. But if your tire clearance is tight be prepared for even more rubbing. Need to make quick disconnects.
