2022 Expy Digital Dash Guages and 15” tablet
rob4092xx
Phoenix, AZ
Does anyone know if the 15” tablet option include the LED dash guages on a 2022 Limited? The order guide is unclear.
rpw2021
Philadelphia, PA
Yes I believe the Sync 4A option includes the all-LED dash, as opposed to the standard combo analog and LED dash.
dlcorbett
Air Force
tx
Above is correct. The 12in screen gives you the traditional dbl gauge with 8in menu screen In the middle while the 15in screen gives you the 12in fully digital menu tach.
dlcorbett
Air Force
tx
Side by side where u can see the tach display for both opt
Scottorama
Iowa
wow this really drives it home for me, that 12" display with the real buttons just completely crushes the 15" config. no comparison.
Just wait until you blow a fuse and the entire dash quits working.... you wont like it then
Balikas
New Jersey
That would be the problem if he said the 15 inch one was what he liked. From his response I took that he would choose the 12 inch screen with physical buttons over the 15 inch screen.
Moderator
That could be the case even with the manual looking buttons and knobs. They are all connected to the other modules and data via the CAN Bus. If you lose that fuse, you would lose them also. This reason is founded in lack of understanding in how this stuff works...
Moderator
Also, the 12 Inch is the same display that is in the 150, and I LOVE it in my new 2021. That being said, not getting the digital dash is a deal breaker for me. It is AMAZING in the 150.
USKflt
The 12” in the expedition outweighs not having the digital screen in my opinion. I was very disappointed to see everything with the 15” screen initially, and I was stoked when the order guide came out and it was an option. Love the screen in the F150 and hate capacitive touch buttons for HVAC. Ford has tried this before on a Fusion and Explorer we owned and despised them. There’s a reason they moved back to physical buttons.
Moderator
I look at the digital dash for all the important stuff. It show me more info, and crisper than the analog gauges. Digital MPH inside of the round MPH gauge, so the center can be used for other stuff. As relatively little as as I touch the HVAC, no big deal. Tech has come MUCH further than those that you have had experience with in the past. Plus the 15 does have at least a single knob. I do agree, I would like digital dash, and the 12, but will be perfectly fine with the 15.
balthisar
SE Michigan
I'm not sure the last time I blew a fuse on a circuit I wasn't plugging my own stuff into.
I'm happy to have the 15", based on my Mach E. Yup, I miss my buttons for certain things, but it's, huge, and works well. I hope that the digital cluster will draw an analogue speedometer for me, though. I freaking hate looking at numbers for my speed.
R
rob4092xx
Phoenix, AZ
I want the digital dashboard. Don’t care about the 15” screen. One question….with the 15” screen are the HVAC knobs gone and all adjustments made on the 15” screen? Not sure I will like that.
dlcorbett
Air Force
tx
I do have a question since you have mach e. Are the natural voice controls Intuitive and accurate, or is it kind of shotty?
Moderator
The digital speedo is in the middle of the Analogish speedo. If you want all the lines and the numbers, you probably won't like it. Look up vids/pics of the F150 Digital dash, because that is what it will look like.
Sync 4's voice prompting is MUCH better than 3's but not quite Alexa smooth. If that makes sense.
USKflt
That’s my biggest beef with the F-150 digital dash. Couldn’t figure out how to simulate an analog gauge. I just didn’t care for the single line with a digital number. Maybe they’ll change that in an update or maybe they already have. I actually prefer the other dash for that reason.
wkendri213
Streetsboro, Ohio
I placed the order for my new 2022 Expedition King Ranch today. I got it with with the new paint, Forged Green, the same as the new Timberland. They said 4-6 months before arrival. I was the first to place an order at Autonation East in Cleveland, Ohio. It comes standard with the digital gauges and the 15.2 info screen.
