Bilstein 5100 Lift Install
FlyBry
Dallas, TX
Ride Height is controlled by the Springs, If too much sag, you can add Sumo Springs.
Tons of towing information in this thread, give it a search in the 4th Gen forum.
Platinum Towing Experiences​
fxpedition
View attachment 41269 Got my expedition 5100’s installed today. Top setting in the front (~1.6”) middle setting in the rear (~.7”). Levels it out a little but still keeps some rake which I’m fine with. 285/70r18 ridge grapplers on factory fx4 rims. Top pic is before, bottom after.
On the top is no lift, correct? Any rubbing at all under articulation with either setup?
Fastcar
Army
FL
Thanks man. Yea I know that and ended up starting with the middle ring which was close to 1.5" taller than the Readylift. Stock setting matched great for the 4wd version. I have the 2wd shocks in the garage in case the rear came out lower than the RL kit as I didn't want any reverse rake.. but it worked out great.
The 2wd F150 shocks are about an inch shorter so close to the top setting may have worked..
F150 4wd Bilstein B8 5100 24-248129
Collapsed Length (IN) - 16.91
Extended Length (IN) - 22.46
F150 2wd Bilstein B8 5100 24-253222
Collapsed Length (IN) - 16.05
Extended Length (IN) - 21.40
Expedition Bilstein B8 5100 24-285056
Collapsed Length (IN) -16.10
Extended Length (IN) - 20.95
Thanks for posting ALL the info! The Part#'s and comparisons are really nice to know.
fxpedition
Do these rub at all when articulated? On either stock or lifted?
akout
kuwait
With IRS, the rear differential is fixed in location. The picture below was taken from in front of the rear axle. The bar with the red arrow pointing at it will pull the wheel forward as the wheel goes down.View attachment 40757
Is there any aftermarket solution to this , really like the way expys looked lifted but this gap almost ruins it , once you see it you cant unsee it
idahoexp
idaho
Can anyone confirm PN's for doing the 5100's for a '21 Expy. Do I use the F150 shocks from 21 or 20?
24-323680 shows for 21
24-248129 for 15-20
Can't seem to find the f150 fronts anywhere - has anyone found stock lately?
apex96
24-248129 for 15-20
For the 2021 Ford Expedition the part numbers are
Front: 24-285056
Rear: 24-285063
96grimreaper
Picked up F150 fronts and Expedition rears for our 19 XLT 4x4. Also have some 295/70/17 Nitto Recon Grapplers going on Raptor beadlock wheels. Planned on going with the stock setting in the front and 1.6 on the rear.
Just to verify, on the stock/bottom setting on the fronts you guys were getting 2-2.5" of lift from the front after settling? Factory, the rear is 1" high.
Just a pic with the raptor wheels and the 315/70's from my F150 to make sure she liked the wheels.
Edit:
Installed. Ended up with 2.75 up front and 2 in the rear before tires.
duneslider
Utah
Just out of curiosity, with the expedition specific bilsteins at the lowest setting do you get any lift? I ask this because I put the bilsteins on my xlt and didn't think it lifted it at all but when I got my 2020 platinum it feels/looks lower than my xlt was. It also feel lower when I try to slide under it. Just kind of curious if maybe I did get a little lift out of them on my other.
Both those black lifted expy's look nice. My xlt was black too.
APExpo
Kentucky
No, they’re adjustable 0-40 mm (about an inch and a half).
expeditiondriver
That looks great; I bought Bilsteins and then changed my mind to get Icon before ever installing the shocks. I didn't think they would end up lifting it that much; but it's a really good and balanced look.
gaspass
Scottsdale, AZ
Bilstein 5100s all around at max height setting (Expedition-specific version). Method 316 Titanium wheels. Falken Wildpeak 275/70r18. No rubbing at full lock and everything looks to be in nice proportion.
Looks great! Which offset did you buy on your Method wheel? Also what is your final wheel diameter after installation?
I am actually looking at the 703 with Beadgrip but want to get an idea.
zeg5000
Denver, CO
The offset on the the Method 316 wheels is +18. The wheel diameter is 18 inches and width is 9 inches. If you're asking about the tire (not wheel) diameter after install, I haven't measured. But, the specs on the Falken Wildpeak 275/70r18 show a diameter of 33.4", which is a bit taller than other tires in 275/70r18 that I considered. As a I said, this wheel and tire combo fits perfectly with the Expy 5100s. I believe the Method 703s you're looking at do not come in an 18 inch size (17 inch only?) and are also a bit narrower than the Method 316s since they are off-road wheels. I really liked the 703s but wanted to go with an 18 inch wheel. Hope this helps.
GreatExcape
Lifting this thread up again for a question...
Has anyone matched the 2WD F150 Bilstein Fronts with the Expy rears... I'm wondering if the 2wd version would let me have adjustments in the 1-3" range since the shocks run about an inch shorter than the 4wd set?
sagebrush07
Boise, ID
Hey all, I just installed the Bilstein F150 up front and the expo on the rears of my 2021 Expedition Max XLT. Definitely a lot more "noise" in the front suspension now. I wouldn't say it's clunking as much as it's just noisier. Everything appears tight. Any one experience this with Bilsteins?
Weinerb
iowa
Tire size question:
I'm planning on installing the F150 5100's on the lowest setting up front and the Expy 5100's top setting rear on my 2020 expedition Limited. I want to keep the factory 20" wheels....will 285/65r20 Nitto Ridge grapplers fit?
