Drive mode default
Linegtdt52
DFW, TX
I’m getting I’m sick and tired of having to reselect drive modes every time I get into the vehicle. My 21 Superduty remembers the last drive mode used and defaults to that. Is there a way to do that with a 21 Expedition? TIA
aggiegrad05
North Texas
Nope. They have to make it default to "normal" because that is the mode they got certified with the EPA for the gas mileage numbers and that is what applies to Ford's fleet-wide CAFE numbers. Your Super Duty (well, not just yours, all SuperDutys) are factored into Ford's CAFE using a different standard so they can allow those larger vehicles to remember the drive mode.
I think some of the aftermarket tunes come with a default change, so it might be possible with FORScan, but I don't know.
L
Linegtdt52
DFW, TX
Gotcha. Would you know if that mechanism is on the TCM or the ECM?
I doubt it. I can’t get ForScan to even link into the BCM at this point. As for my SuperDuty, no issues. I could, however, make changes in the IPC module for temp display on the cluster but I can’t turn on Bambi Mode or Secure Idle which is BS. I keep getting a service interruption when I try changes on the BCM…‍♂️
Rob6805
It is very annoying in the winter. I would like it to stay in snow mode until I take it out.
Moderator
If you have a 21 Expedition, please go to the FORSCAN area, there is a thread where the Beta version of FORSCAN is posted that will work with a 21. Search is your friend.
Also, DO NOT use direct line code changes from any previous Expeditions, as the 21's are even somewhat different than the 20's. Use the drop downs.
Also, FORSCAN cannot change the default. It will default to Normal. The 21 150's ask you. If you don't answer in a few seconds it goes back to Normal.
wakeboarder
Fort Lauderdale, FL
I have done it on my 2019 2wd. It works 95+% of the time.
KFordEx8
SF Bay Area
I was wondering about the same thing. Sometimes forget to put it back into Tow mode after stopping.
Janky
Seattle, WA
Hmm, my 2018 Platinum seems to do just fine setting tow mode whenever the electrical plug is inserted. It informs me the next time I start it that it's off - no trailer detected. Nice feature, but dumb that it has to display an alert for 10 or so seconds unless I hit the ok button.
wakeboarder
Fort Lauderdale, FL
it stays in the mode your were in before you turned the vehicle off and exited?
Yes, it stays in the same mode as the last time I drove it.
See thread below. It also list some of the pluses and minuses.
Moderator
But not factory, and not a FORSCAN change. You spliced a module into your wiring harness.
Moderator
If you unplug the trailer with the Expedition running, you should not get that message at the next startup. It is because the trailer was plugged in when the vehicle was off, last it knew you had a trailer connected.
wakeboarder
Fort Lauderdale, FL
This is just the trailer detected relative to the instrument panel. It does not affect the drive modes.
Password
I'm one of those guys that made direct line changes, I didn't know there were drop downs when I first started using forscan. I tried to revert a setting back to the original code (auto start/stop disable) but not the start/stop only works when it wants to. I tried changing it through the drop down afterwards but it didn't help. A couple issues that I think may be a culprit.
1. i tried the the revert with a newer version of forscan than what I used to make the changes.
2. The new version of forscan now warns me able my adapter, because it is not one of the adapters listed on the forscan website. My adapter worked fine when I made the initial changes.
Should I try an older version of forscan to try and fix the start/stop function?
Moderator
Did you backup the stock settings on the module before you made changes? If not, you can ask in the FORSCAN Area for the coding from another 2018 with similar options. You can then compare.
ALWAYS back up the whole module before making line item changes. It is part of the basic tutorials on FORSCAN usage.
Password
Of course I didn't.........I figured I could just change the one digit back to the original number and there be no problem. I wrote down what I changed on paper for when this time came around.
Password
Looking at this post, maybe I don't have a problem. I've had the function disabled for awhile, I don't remember exactly how often it would turn off. I'll have to watch the display and see.
Moderator
The problem is that one digit can cause another digit to change based on the total coding of that line. That is why you should always backup the modules, AT LEAST once before you start making any changes, so you can go back to default.
Password
Ahh, I see now.
bryz_expy
Denver, CO
Forscan experts: Three things…
1.) Is it possible the asbuilt from that super duty could be decoded to determine what setting preserves drive mode?
2.)One thing I would like is setting sport mode and staying in 2wd. My 18 F150 did this but my 19 Expedition changes to 4a.
3.) my F150 is long gone but I still have the old Forscan backups from it. Is there a way to view the asbuilt info from the trans settings external to Forscan? I can compare trans setting to see if I can accomplish #2 above.
Thanks!
