Whats your oil & why do you use it?
ssbroly
Valvoline max life. 5w-30. Affordable, reliable, used it in all my vehicles. Never an issue.
tmajikman
Cartersville GA
Some type of semi synthetic my buddy uses at his Oil Change shop, for 32.00 bucks he checks all the fluids, tires, and fills everything up, it is well worth it, and he is the only person I trust to work on my vehicle....5w30 btw
METALLICA
philippines
voltronic, it's what my ford dealership offers :) but i want to go back to castrol tho
panda24619
San Diego
castrol high mileage 5w30. works great and keeps my valve knock down to a minimum in the mornings. my dads always used some sort of castrol. we use gtx on all the other trucks and thats what i used before i switched high mileage.
KWT2000
NINE MILE FALLS
valvoline full synthetic 5w30 i use it because i always have used it and they make full synthetic oil for my boat and motor cycle.... in the diesel pick ups and semi i use rotella full synthetic 5w40
seeker
Acworth Ga
my oil
motorcraft 5-30 from wally world. syn-blend. If i cant find that then i use Valvoline.
HFFH
sacramento
ive always used castrol 10w40 or 20w50 along with the luccas oil additive and had no problems. my 99 f150 is about to 300 000 and my 99 expy has 125000. my dad allways used castrol so i did 2 lol
slo-ryd
Ky
Kendall GT-1 Full Synthetic 5w30
It's what my shop stocks, it's reasonable and I actually met with one of the engineers that worked on the Liquid Titanium anti wear additive(for 5 years) that is in the new formula and it's no gimmick.
My shop does 350 oil changes a month with Kendall synthetic blend bulk oil and never an engine failure in the years I've been there.
Most oils are good, but I've seen first hand how bad Quaker State can sludge up a motor. I can believe anyone would use it.
ExpySport
Media, PA
Motorcraft 5W-20 Synthetic Blend, FL-820S oil filter. I've used it because it is affordable, reliable, recommended and has received a lot of positive reviews and feedback from other Ford owners. Always use the FL-820S filter, as well. In almost 150k miles, never had an issue.
