Aftermarket Clear Headlamp Housing??
Yoop33
St. Orlampawaterton Islands, Florida
I have these already and am looking for a new set. Mine are looking kinda dingy and for some reason point to far down infront of the truck to really see much. Thank goodness for the fog lights. Anyone know where I can find a good brand clear headlamp? As in no amber reflector in a black housing??
Thanks
panda24619
San Diego
my passenger light is has the yellow film on the light all scraped off. so yellow driver white passenger. i want to scrape the rest off and do the drivers. idk why it started to scrape off though. its so random.
Newport News, VA
my bulbs just blink white...nothing scraped off or anything...probably why the OEM headlamps have the yellow marker
Racenut
Deming, New Mexico
The yellow marker in the turn signal assembly is a reflector and is DOT required. It is there incase of the bulb itself goes out then other headlights will illuminate the reflector and they will be able to see you. Same goes for the tail lights.
Most cops will not mess with you for not having the reflector, but it does give them a reason to pull you over if they want to be PR*CKS! If you have any kind of vehicle inspection where you live they can also fail your inspection for not having DOT compliant lighting on the vehicle.
