Help Determining If I have Tow Package
msquared
CA
Hi All -
Just bought my wife a 2006 Expedition & am trying to determine if it has the tow package or not. It has the two small oil coolers visible from the lower front grill. The sticker on the bottom of the hitch says 8950/6000. However, there is NOT a 7-pin wire harness at the hitch.
It's an Eddie Bauer 4WD.
So, if I buy a weight-distributing hitch, am I good to tow up to 8600(or 8950)???
Thanks,
M2
P.S. Love the site.
Racenut
Deming, New Mexico
Since you do not have the heavy tow package, then you are good to tow a 6000 pound trailer with out a weight distribution setup as long as you do not exceed 600lbs tounge weight.
If you purchase a weight distribution hitch setup then you are good to tow a trailer up to 8950 pounds as long as you do not exeed 895lbs tounge weight.
NOTE: THIS IS THE MAXIMUM HITCH RATING MAKE SURE YOU DO NOT EXCEED YOUR GCWR.
If you had the optional heavy tow package then you would have BOTH the 4 pin and 7 pin conectors at the hitch.
panda24619
San Diego
mine has the tow package. but it dosent have the 4 pin. i think thats cause its a 1st gen? idk. the trailer i tow is small. about 2 quads on end will fit.
M
msquared
CA
Thanks for the info RaceNut. Just curious. IF I had the heavy tow package, what more would that allow me to tow?
Racenut
Deming, New Mexico
Panda the first gen expy's came with the 4 pin if ordered with a reciver hitch, but came with a 7 pin if ordered with the optional heavy tow package, wich also encluded either the 3.55 or 3.73 rear end gear ratios, upgraded radiator and tranny cooler, and prewired for trailer battery charging, trailer brake system and also for trailer reverse lights. The newer Expys and trucks that have the upgraded heavy tow package come with both the 4 pin and 7 pin side by side ( makes it nice so you don't need an adapter ) or just a 4 pin if it does not have the optional tow package. I just wish they would have thought about that for us 1st Gen guys.
Racenut
Deming, New Mexico
THE MAXIMUM RATING OF THE HITCH WITH WEIGHT DISTRIBUTION IS 8950LBS.
If you had the optional heavy tow package your base line trailer weigh would be 8600lbs with a MAXIMUM GCWR ( Gross Combined Weight Rating ) OF 14,500LBS ( Expy, trailer and all persons and cargo together ) of course with ANY of these weights you would need to have operational trailer brakes either hydrolic surge or electric.
WITH THE STANDARD TOW PACKAGE ( 4 PIN ) Your GCWR is only 11,900lbs so if you figure that the Expy weighs in around 5000lbs ( **NOT SURE HOW MUCH YOUR EXPY WEIGHS, MAKE SURE TO HAVE IT SCALED AT YOUR LOCAL TRUCK STOP TO FIND OUT** ) and a trailer of 6000lbs that puts you at 11,000lbs so you would only have an aditional 900lbs until you are at the maximum weight rating of YOUR Expy ( with out optional heavy tow package ) with weight distribution.
Sorry I forgot to put in the GCWR ratings in the first reply. THE NUMBERS IN THE FIRST REPLY ARE HITCH RATINGS ONLY.
M
msquared
CA
If you had the optional heavy tow package your base line trailer weigh would be 8600lbs with a MAXIMUM GCWR ( Gross Combined Weight Rating ) OF 14,500LBS ( Expy, trailer and all persons and cargo together ) of course with these weights you would need to have operational trailer brakes either hydrolic surge or electric.
OK, understood. I'm wondering...
Since it's a 4WD, I should have the 3.73 gears. I confirmed there is an electronic brake control connector under the dash & a 5th wire for it at the 4-pin connector. If I upgraded the radiator & the tranny cooler, wired a 7-pin (I read elsewhere on here how to do that)...would it get me to 8950#?
Racenut
Deming, New Mexico
In theroy it should, the only thing I am not sure on is if they have a different shift stratagy in the computer program for towing ( which a programer like an EDGE would take care of) . I would go to your local ford parts department with your vin # and have them pull up the AS BUILT specs for your vin.
This way you will know everything that is on your truck. Since the As Built page will show all factory options along with any Extras the truck was ordered with.
It is a very useful page to look at and they are the only ones with access to it but it will show gear ratios, interior and exterior options, power train options, tranny and t case, basically every part that was put on your truck is on that sheet.
Racenut
Deming, New Mexico
One other thing to look at would be your suspension.
Do you have air ride or springs?
If you have springs they may need to be changed out as well to compensate for the extra load.
JUST4FUN
Admin
Moderator Administrator
Il
RACENUT
WITH THE STANDARD TOW PACKAGE ( 4 PIN ) Your GCWR is only 11,900lbs so if you figure that the Expy weighs in around 5000lbs.
WHAT!!! please stop giving false statements . 4 pin connectors DO NOT HAVE TRAILER BRAKE PROVISIONS. In most states any trailer over 3000 lbs
must have trailer brakes.
PLEASE post with care,people can take you info to heart and end up hurting
or killing someone...
ADMIN
Racenut
Deming, New Mexico
RACENUT
ADMIN
JUST4FUN
I am not trying to come off as an *** but I am defending the information that was put out.
MAXIMUM GCWR ( Gross Combined Weight Rating )( Expy, trailer and all persons and cargo together )
All of the GCWR numbers came right from the Expedition owners manual and if you look at the same post you quoted the first paragraph last sentence says
"of course with these weights you would need to have operational trailer brakes either hydrolic surge or electric."
Also in the same post I also wrote
"( **NOT SURE HOW MUCH YOUR EXPY WEIGHS, MAKE SURE TO HAVE IT SCALED AT YOUR LOCAL TRUCK STOP TO FIND OUT** )" This was put in so that he can figure out the exact weight of trailer that can be safely towed without going over his GCWR.
POST #7
QUOTE: I confirmed there is an electronic brake control connector under the dash & a 5th wire for it at the 4-pin connector. END QUOTE
The expy HAS the brake contoller provisions PRE WIRED in the harness. All you have to do is get under the truck at the rear wiring conector where the trailer harness is plugged in and get the controller wire that is there. Then under the dash right next to the obd II port is the PRE WIRED conector for hooking up the controller.
I am not trying to give out FALSE STATEMENTS this particular user under stands that he has to have trailer brakes and has also already looked to make sure he had the provisions for them and also stated that he knows how to change the connector over from a 4 pin to a 7pin.
He wants to know what his Expedition is SAFELY capable of towing and the information that I was giving again came from the OWNERS MANUAL.
I have been towing for many years and the last thing I want is someone getting hurt.
Racenut
Deming, New Mexico
This is straight from the 2006 model year owners manual:
http://www.motorcraftservice.com/pubs/content/~WO6EXD/~MUS~LEN/41/06exdog2e.pdf
PAGES 236 & 237
4x4
5.4L with standard trailer towpackage
GCWR 11900LBS TRAILER WEIGHT RANGE 0–6000LBS
5.4L with optional trailer towpackage
GCWR 14500LBS TRAILER WEIGHT RANGE 0–8600LBS
Note: For vehicles not equipped with the optional trailer tow package,
the maximum frontal area of trailer should not exceed the frontal area
of the vehicle (3.4 square meters [36.5 square feet]).
Note: For vehicles equipped with the optional trailer tow package, the
maximum frontal area of trailer should not exceed 5.6 square meters
(60 square feet).
Do not exceed the maximum loads listed on the Safety Compliance
Certification label. For load specification terms found on the label, refer
to Vehicle loading in this chapter. Remember to figure in the tongue
load of your loaded trailer when figuring the total weight.
Towing trailers beyond the maximum recommended gross trailer
weight exceeds the limit of the vehicle and could result in
engine damage, transmission damage, structural damage, loss of
control, vehicle rollover and personal injury.
Integrated hitch rating
The standard integrated hitch has two ratings depending on mode of
operation:
• Weight carrying - requires a draw bar and hitch ball. The draw bar
supports all the vertical tongue load of the trailer.
• Weight distributing - requires an aftermarket weight distributing
system which includes draw bar, hitch ball, spring bars and snap-up
brackets. The vertical tongue load of the trailer is distributed between
the truck and the trailer by this system.
Weight carrying
MAXIMUM GROSS TRAILER WEIGHT 6000LBS
MAXIMUM TOUNGE WEIGHT 600LBS
Weight distributing
MAXIMUM GROSS TRAILER WEIGHT 8950LBS
MAXIMUM TOUNGE WEIGHT 895LBS
These are hitch ratings only; actual vehicle ratings are dependent on
engine, transmission and axle combinations.
Towing trailers beyond the maximum tongue weight exceeds the
limit of the towing system and could result in vehicle structural
damage, loss of vehicle control and personal injury.
JUST4FUN
Admin
Il
the seconf paragraph sounds like your describing the weight limits to a 4 pin connector as being 11600 lbs, and that you only need a brake control for 14500lbs thats how i read it
JUST4FUN
Admin
Il
this sounds great ,good info....
this makes it sound like i can tow up to 11,900 GCWR with a 4 pin connector
thats what i was trying to get across
Racenut
Deming, New Mexico
I should have worded it different.
The owners manual says that the standard towing package GCWR is 11,900LBS which allows for a 6,000LBS trailer but it only comes with a 4 pin connector and prewired for trailer brakes which are a necesity.
The only reason that I had put the 4 pin in there was to identify the towing package that he had.
hautevue
Baltimore, MD
I definitely concur with Racenut--run do not walk to your friendly Ford dealer with your Expy VIN and get the Parts Dept to print out the "as built" sheet from Ford. Only the dealers have access to this.
This will give you every little thing on your Expy, and should be filed away with your "valuable papers". I carry a copy in my "glove box" when traveling.
It has all the Product Numbers -- these numbers code stuff like rear end ratios, tranny type, engine size, etc., as well as towing info. Worth the trip to a dealer. Knowing you have funny Ford codes like a "QM47G" rear end isn't really helpful, but at least you can then ask the dealer what the codes translate into. The Parts Dept guys work with the codes all the time--we don't.
