Rear wiper delete
69ford99
KS
I did a rear wiper delete, super easy. Has anyone else done this?
69ford99
KS
1. I don't use it 2. It looks better without it 3. The rear wiper can cause issues with battery drain.
smith627
Mississippi
My front and rear wipers work but recently they won't spray water on windshields when I press the spray button.
BigRed2004
Las Vegas, NV
How did you go about performing the delete? I live in an extremely dry environment and have rarely ever had to use the rear wiper. So a delete may not be a bad idea. Especially since currently the shaft more or less free spins when activated and doesn’t wipe. It not working is not the reason for hardly using the rear wiper. There is just literally less than 7 inches of rain fall a year.
Johnathan M
Klingerstown, PA
What do you grab onto to open the rear glass? I had an 05 and the rear wiper would occasionally get tight and I would have to disassemble it and clean and lube things up so it would rotate. Was a pain.
JamaicaJoe
Oviedo FL
I have a 2001 and I am considering deleting it as 1) It has not worked since I disconnected it due to battery drain. 2) New replacements are hard to find, 3) It makes the door heavy and noisy when closing.
69ford99
KS
You can grab the edge of the glass after you hit the release button. After I took the wiper off, I just unbolted the latch which has the wiper shaft on it. I then cut the part of the bracket that had the shaft on it. Now all I have is a hole in the glass which is about the size of a 22 mm socket. You can buy a delete kit on Amazon, I used a beauty cap off a dual monitor stand and sealed it with some E6000.
69ford99
KS
Here's the plug I used. Like I said it's off a dual monitor stand.
69ford99
KS
I already had the dual monitor stand, it's an ergotron brand. I don't have a part number but if you search for rear wiper delete on Amazon it shows a bunch of plugs.
samsonite
sweden
After motor removal the washer stopped! Does anyone know how bypass the connector so that the washer fluid works in the front thou the motor is removed to the rear wiper??
