Marvo75
What all has to be done to the gears to run 35's? Pinion swap?
yeah any time. if you do mostly high way driving gears are what you need. if you have a4wd full time or if you use 4x4 a lot then you will need 2 sets. other wise if its 2wd and you never use 4wd then just get the one set till you need the front set.
