Expedition 2019 Platinum 4A mode really "auto" or is it actually 4H?
dtximages
Dallas, TX
When you're on the "Power Distribution" screen you can see which wheels are getting power. Obviously, on 2H only the rear wheels get power. But, on 4A, I've noticed all four wheels get power ALL THE TIME, NOT JUST WHEN NEEDED - which is what most 4A's do. Is this really the case? If so, why not call it what it really is -- 4H, not 4A.
Am I missing something?
2020FordRaptor
Nevada
So the 4a will engage almost every time from a standstill but once you get up to speed it'll disengage.
Rob6805
The 4A power distribution is dependent on which drive mode you are in. At least this is the case with my 21.
1badhabit
Missouri
In a straight line 4A will almost always apply power to the front wheels. It will not when turning unless traction conditions dictate it's needed.
4H applies power to the front regardless of steering input or traction conditions.
Beachums
Indiana
4A engages the front hubs. At that point the front driveline is turning with the wheels (hence the lower fuel mileage). Based on what the Terrain Management computer dictates, either it locks the center diff 50/50 (Mud/Ruts, Sand)... or the transfer case is then monitoring the output shafts to the front and rear differentials. When it sees a difference, it will actuate a set of clutches to add torque to the front driveline.
sjwhiteley
Kentucky
If the management system thinks it needs it, then it puts power to the front. If you see power applied to the front wheels, then I guess it thinks it ‘needs it’. Ergo, as needed seems correct :)
Silver-Bullet-Bus
South Carolina
There is 4A, which provides limited slips,
Where the power train control module can shift power around based on traction & or slipping,
Vs the 4H, which is 4wd, locked up, in high on the transfer case
D
dtximages
Dallas, TX
Interesting and thanks for the feedback. I guess that's why it defaults to 2H. I've always driven in 4A in my other cars and Fords as they applied zero power to the front wheels unless the rear wheels slipped.
chuck s
My 2017 (Gen3) works the same way as above in 4A. I call it "Subaru mode" (we've had 3 of them) as it seems all wheels get some power all the time when viewing in the "off road" screen. I normally run 2H and can feel the engine load increase with switching to 4A so running the front axle seems to be just adding wear when I don't need power to the front.
-- Chuck
D
dtximages
Dallas, TX
Here's what really bothers me about this mode though. When you put it in SPORT mode it automatically shifts to 4A sending power to the front EVEN ON THE INTERSTATE. To me, SPORT mode should just adjust the transmission or maybe even fuel to give more power/sportier feel. But Sport is actually an "offroad" mode I guess to Ford.
rd618
new york
It does that to prevent wheel slip.
On my 22 if you put it in sport and put it in 2H I can break the rear tires loose. In 4A the front hubs engage somewhat so no loss of traction.
On the interstate it prioritizes rear tires with low transfer to front. It can adjust the amount of torque front axle gets in 4A.
4H (which I have in 22, but you don’t in 21) locks the center clutch packs as tight as it can to send equal power front and rear. You can engage a similar mode if you select sand or mud and ruts.
4L is the same as 4H, but with the 2 speed transfer case switching to higher numerical gear ratio.
D
dtximages
Dallas, TX
I understand it's to prevent wheel slip but that's never an issue at interstate speeds.. I might understand only at launch. The point is that 4x4 is constantly locked-in in 4A where I don't think that's the case with other brands.
sjwhiteley
Kentucky
Not seeing the problem, here. 4A seems appropriate. It automatically applies 4A when needed. If you are in 'sport' mode, the likelihood of needing more traction is increased, so applies some to the front wheels, as well as the rear. It's not 'locked in' as it can change based on requirements.
I don't have 4H, but would likely run 4A in all but the most aggressive off-road conditions. 4A does great in mud, snow and dry conditions, and responds appropriately and efficiently.
rd618
new york
This is where you are wrong. 4A is never “locked” unless you’re in a specific mode. As I mentioned above.
4A adjusts the torque to front and rear as needed.
Could be 10%, 25%, 50% etc to front. Not like that gauge on the dash is accurate. Just an image people get an “idea” about what’s happening.
If you want 0% going to the front. Turn off 4A and put it into 2H.
By you selecting 4A you’re telling the truck “I want some amount of potential torque going to the front”.
D
dtximages
Dallas, TX
Thanks, maybe I have always been wrong about what 4A really meant then. I thought it literally meant 2H until slippage is detected then it immediate activates the front axle. Now I'm learning there was always some power being sent to the front.
But if it's considered "smart" I don't understand why it would ever send power to the front while driving 70mph+ on a dry interestate under mild accelleration.
rd618
new york
What you’re describing makes sense. There are many other systems that do exactly that. But normally you don’t get to select the modes. Explorer is a good example.
For the expedition it has the ability to send 0% up to 50% to the front axle while in 4A. I however do not know when it sends 0% front and what conditions would motivate that behavior.
xmountaineer
WV
I’ve only owned my 19 max (with the hd tow package) for about a month but so far I must say that I am not overly impressed with 4A. I live on a gravel road and my driveway is also gravel, long, somewhat steep in sections and has one big turn going up the hill. This section is definitely not steep. I engage the gravel/grass/snow mode before getting on my driveway. When I go around this turn about half the time the traction control light comes on and the power gets cut way down. I’m going no more than 10mph. It never feels like the front tires grab. There should be no way that the traction control light should come on in this situation if 4wd was truly working. At minimum the elsd should kick on, right?….and front tires should pull me up. Next time I’m going to put the power distribution graphic on the display and see what happens. I engaged the elocker one time and won’t ever do that again going around that turn, it seemed like it struggled even more, likely because of the turn. I can zip right up my driveway with a front wheel or awd vehicle with zero traction issues.
Rob6805
Try the mud/ruts mode next time. I believe this is the one that creates a true 50/50 split like conventional 4H would.
chuck s
Based on my experience with two (2) Gen3 Expeditions I can state 4x4 is certainly "locked in" in 4A. I can feel the engine load change when switching into and out of 2H and 4A when driving at a constant speed on on level, dry ground. Engine is working minutely harder. For that reason I do not run it as a normal setting. "Pretty sure" -- meaning "I don't know" :) -- all this is the center differential engaging and disengaging, with the front axle being a dumb axle.
Gen4 guys give this a try and see if you can feel something.
I have 2H, 4A, 4H, and 4L available and rarely run in other than 2H.
-- Chuck
balthisar
SE Michigan
And also he can look at the power distribution screen and actually see when and under which conditions power is routed to the front. 4A really, really isn't 4H.
