It'll fit perfectly. Agreed that it would look awesome!I've read that the engine in the Stealth Performance model expy (440 hp) is the same as the F150 Raptor engine. Would the Raptor engine cover fit the Expy?
Has anyone done this.
I think it might look bad ass
And it's honest because it's the same engine!
Thanksit will fit... someone here has purchased this and installed.
I purchased it, and it will not fit on the SPP. There is a bracket with cables on top of the intake, attached to the rear of the throttle body that prevents the cover from fitting down onto the intake. I ended up giving the cover to my son who installed it on his F150 with the 3.5L Ecoboost. Fit his engine perfectly.
Here are the part numbers -
Here are a few pics of the Raptor engine in my SPP. Note the device, I believe related to the EGR system, sitting over 3.5inches above the top of the intake. This is why the Raptor cover will not fit. I even tried trimming a portion of the cover out in an attempt to make it fit. No luck.
YesBy "SPP" do you mean Stealth performance package?
Thanks for the info.
Oh wow, I guess the spp added or rerouted some hoses. My 2018 does not look like that on top of intake
Thanks for this report. I would have ordered one.Here are a few pics of the Raptor engine in my SPP. Note the device, I believe related to the EGR system, sitting over 3.5inches above the top of the intake. This is why the Raptor cover will not fit. I even tried trimming a portion of the cover out in an attempt to make it fit. No luck.
Finally, I got engine cover for my Timberline from eBay Canada:
21 thru 22 F-150 OEM Ford RAPTOR 3.5L Ecoboost Ford Performance Engine Cover
Link below.
<snip>
Your SPP is same engine HO my Timeberline 22Exactly what year/model/etc expy did you install on?
dhenderz' post here seems to be saying I am out of luck on a 2023 SPP
https://www.expeditionforum.com/thr...rmance-raptor-engine-cover.52018/#post-478301
Can you pull that cover off and take a picture of the engine without it? I don’t have my ‘23 yet, but when it comes I want to see if there are any changes before ordering the cover.Your SPP is same engine HO my Timeberline 22
To be clear, my SPP is a 2022, built in late spring, took delivery in July. And again, I did purchase the exact Ford Performance cover (receipt with part#s in earlier post) and it does not fit - PERIOD.
