Catalytic Converter Protection - 2023 Timberline
TimberTex
Houston
Picked up my new 2023 Timberline earlier this week and talked with the parts guys while I was there about any kind of protection available for the catalytic converters. According to them Ford offers nothing. The Ford dealer also owns a Toyota dealership nearby and the Ford parts guy directed me to them because they work with a company in town that makes shields for them but also makes them for other brands including Fords. Went to the the Toyota dealer today to get this thing installed and wanted to share pics with y'all showing all of the skid plates from the factory, what covers your cats now, and what this shield looks like. I've seen a post on here about skid plates so I took the opportunity to look around while it was up on the lift.
The front skid plate seems pretty solid and the one under the gas tank is tougher than I thought it would be. That one is plastic but it feels thicker and more rigid than I expected. The material that covered the cats from the factory is essentially a flimsy heat shield on one side and felt material on the other. It provided no under body protection at all.
I will say Ford does a better job tucking the cats up into hard to reach places than Toyota does. The ones on my car are in between the frame and transmission and aren't as accessible as you'll see on Tundras and Tacomas.
1) Factory cover that got replaced
2) Front skid plate and new shield
3) New shield
4) Underbody as it comes from the factory
5) Left cat and flexible factory cover
TimberTex
TimberTex
Houston
1) side view of the new shield
2) fuel tank
3) right side cat and factory cover
4) factory cover and both cats
RacerBX1
SE Michigan
The Ford Parts guy at your dealership was wrong and Ford does make a shield for that, but it’s called the “Transmission Underbody Shield” (Part No: NL1Z5D032C) and it replaces the hard felt piece with the heat shielding. I think the one you got might go slightly further back though.
Calidad
Only good protection is garage parking.
However the only houses hit here were in groups of houses with zero night lighting and zero security cameras. Pretty obvious they came trough and eyed the targets before. My neighbors and I have security lights, cameras etc and haven’t had any issues. Helps if you have Prius owners all over the area keeping the crooks busy
TimberTex
TimberTex
Houston
Couldn't agree more about garage parking and thats where I keep mine when I'm home. These guys get people at the grocery store, malls, etc and I just wanted peace of mind knowing mine was a harder target than most. Hopefully they'll get a look under there and move on to an easier car, like something with a Toyota logo on it.
Going_Going_Gone
Phoenix
Spending that much money on undercarriage shielding for a vehicle that I wouldn't use for off roading is something I could not justify. Of course a lot of my reasoning is based on how we use the truck, where we live, and where & for how long it might sit unattended while running errands. But that's just me.
TimberTex
TimberTex
Houston
My protection options…
I get where you’re coming from but in the real world this isn’t practical. Do you bring all that with you and leave it in a parking lot when you’re shopping, or going to baseball game? Are you standing watch after you park or do you go inside the place you just drove to?
TimberTex
TimberTex
Houston
Same can be said for a lot of things. This is a 4 wheel drive, slightly more capable off road trim level but I doubt any of us are going rock crawling in it. The primary reason for the purchase wasn’t off road protection but catalytic converter theft protection. I live and work in a major city and crime is a problem. This device makes my car a little less likely to be targeting in a parking lot and thieves won’t want to spend the time messing with it. They should just move on to the next car. If I lived in rural Montana I wouldn’t have even considered this. Just wanted to share under body pics and a useful product for those that may need it.
Going_Going_Gone
Phoenix
No offense intended. You purchased some first-class hardware--worth sharing; and for you it would seem to be necessary.
TimberTex
TimberTex
Houston
I just wonder about all that heat that shield keeps in.
I'm curious about that too. It isn't air tight by any stretch and does have vents cut into the bottom as well as an access hole to reach the oil drain plug. I'm sure air still circulates through there when you're driving but it does close up a lot of previously open area around there.
m3olsen
CNY
@TimberTex , thank you for bringing this up - I didn't realize we have options. And ty @RacerBX1 for pointing out a Ford alternative in post #3. I unfortunately park outside most of the time, though in a (relatively) low crime area, with street lights and (some) cameras. I will likely look into this for peace of mind.
m3olsen
CNY
For an anyone interested, this is currently $234.15 is Tasca. Has anyone installed the Ford version, and are you happy with it? Is there a pic out there?
Andy B
Redding, CT
If you have under body shields that bolt on you can probably get special security bolts that are hardened and require a key to remove, like locking lugnuts.
TimberTex
TimberTex
Houston
The shield I originally posted about comes with those. Seems like a pretty solid product.
No members online now.
rockinghranch
