Coolant and Transmission Temperature ?? Help
aziz
Kuwait
I just saw this when traffic jam and the transmission temperature rise to 220f when im driving (105c).. but coolant rise in traffic light stop is it normal or should i change the thermostat ??
BMW2FORD
CT
It’s most likely a thermostat but check the coolant level and if OK, feel the upper and lower radiator hoses while it’s running hot. If the lower is much colder, then the T stat is not opening to allow coolant flow. If you’re low on coolant, there could be a leak someplace. Ford does have an updated thermostat with a plastic inner sleeve that works really well for these.
duneslider
Utah
220f is not really a "too high" temp for these though. I wouldn't worry too much at 220f.
mr_dave
MN
The newer transmissions are designed to run hotter than what was traditionally normal.
From an actual transmission engineer:
You can run the trans as high as 220F all day long with NO ill effects. You can go as high as 250F for no more than a half hour at a time.
BMW2FORD
CT
Check out pic -#2 the OP showed. It’s at 233 degrees engine temp when you convert that to F and listing the actual temp as a warning for being too hot so for sure something going on there that’s not right. These transmissions cool or warm from the engines coolant and looks like the engine is getting the trans hotter than normal. I agree, it’s not hurting the trans but not right and getting to the hotter side.
JUST4FUN
Admin
Moderator Administrator
Il
Could it be possible that the shudders are staying closed , I would think the fans would come on and be on high.
aziz
aziz
Kuwait
The fanobecome high right and the coolnat temperature only rised for seconds and then when i drive its back to normal
aziz
aziz
Kuwait
Thanks for the help i will check with Ford dealer next week for service 90,000 km and ask them about it and change the thermostat and check the coolant
aziz
aziz
Kuwait
Today i opened the hood and i found the coolant reservoir is low i add around 1 litres of water tomorrow i will send the car for check ! is it under warranty or not because i start to hate the car
I’d suspect the engine water pump is leaking (even very slowly), which would cause the low engine coolant.
DavidCola
South Carolina
My coolant temperature was spiking (240 F) at highway speeds. No leaks, no air pockets etc. I had the thermostat changed. Problem fixed.
aziz
aziz
Kuwait
Last update they fix the problem under warranty and change sparks and VCT
Now Trans Temp 215F
