JAMADOR
Attempted to change the oil on the MiniBus today, I've done my own on all the cars I've owned, this one defeated me, for now.
Got the underbody panel removed, seems like a tiny amount of room to get to the oil pan drain plug [assuming i was on the right bolt, passenger side, at the rear of the pan?] between the crossmember & sway bar?
Must've been last changed by the Hulk, was worried about rounding it off, so I stopped. I don't have a 6pt wrench, and the 12pt wasn't grabbing right.
My floor jack [1.5t Pittsburgh Low-pro that was for my Lotus 7 replica] also might not be up to the task of lifting the truck either, need to look into an upgrade or QuickJack
Any tips on making this easier? Planning on adding a Fumoto, and maybe run a drain hose to bypass needing to pull the underbody, but getting the drain plug out has me flummoxed.
