2019 Expedition Limited - Dreaded wrench light
chrissbu
Bemus Point, NY
We got our Expedition about a week and a half ago now, and things looked great on the test drive, and the carfax showed that the car had been religiously maintained. But the dealer delivered it to our house, and after hooking up the Ford app, we got a notice in the app of a powertrain malfunction. There was nothing on the dash of the truck itself, and it seemed to drive fine, and after a couple of days the notice disappeared in the app. But today we went out for a short ride, and after about 3 or 4 miles on the highway, we got a "Check Manual" warning, along with "Pre-collision unavailable" and "Drive mode unavailable" warnings, with the yellow wrench. The truck drove pretty erratically at that point, feeling like it was misfiring and just struggling to run smoothly in general. I turned it off for a minute, and upon restarting it, the warnings came back. We made a stop on the way back home, and came back about 20 minutes later, and upon restarting, no warnings or messages at all, and nothing showing up in the app.
I have an OBD reader coming tomorrow, so that I can pull the codes and see what's going on, as some quick googling was more or less inconclusive :( I'm hoping that it's nothing significant.
Mileage?
The vehicle should have a 60,000 miles - 5 year (no deductible) power train warranty.
C
chrissbu
Bemus Point, NY
64k miles, so it's out of the factory powertrain warranty. The dealer provided a 100k powertrain warranty, but they're about 2 1/2 hours away, so we're trying to at least narrow down that it's even something that'll be covered under the warranty before making the drive down (I know, when the truck is explicitly throwing a "powertrain issue" warning, that should be a pretty clear sign, but I think we all know that those warranties have enormous loopholes in them).
SyndicateZ
Mass
Id get your money back now while u can.
The selling dealer cleared the codes before selling. But the a
APP had not updated to being cleared yet. Smells fishy to me
Headache incoming
C
chrissbu
Bemus Point, NY
Headache incoming
Refund isn't really an option :(
I got a reader and hooked it up with Forscan last night. No DTC in the PCM. There were a handful of other codes stored, which I'm still working through and wrapping my head around, but nothing that immediately stood out to me. I do wish the DTCs had timestamps on when they were stored :(
C
chrissbu
Bemus Point, NY
Looking through the handful of stored codes, the one common thread is "lost communication" between systems...anyone else able to find some common threads there outside of a possible issue with CANBUS?
IPMA (These look to have occurred over a couple of different days, based on the freeze frame data)
Code: U0418 - Invalid Data Received from Brake System Control Module 'A'
Code: U0401 - Invalid Data Received from ECM/PCM A
Code: U0121 - Lost Communication With Anti-Lock Brake System (ABS) Control Module 'A'
Code: U0103 - Lost Communication With Gear Shift Control Module A
Code: U0100 - Lost Communication With ECM/PCM A
IPC
Code: U0159 - Lost Communication With Parking Assist Control Module A
Code: U0140 - Lost Communication With Body Control Module
Code: U0136 - Lost Communication With Differential Control Module - Rear
ACM
Code: U0257 - Lost Communication With Front Controls / Display Interface Module
TCU
ABS
Code: U0073 - Control Module Communication Bus A Off
IPC
ACM
TCU
ABS
Was the engine battery replaced prior to your purchase - it does the battery seem to be the original?
I’d bet most of the codes are a result of a weak battery and/or corroded terminal connectors.
Scottorama
Iowa
Was it from a state that has recently had flooding issues? Could be the car was flooded and ruined the electrical system
gtr09
Midwest
This was my first though as well. Bad battery or bad grounds
C
chrissbu
Bemus Point, NY
Battery appears to be original, is a FoMoCo labelled battery. And it's spent it's life in the Pittsburgh area, so I don't think it's a flood damaged vehicle. The Carfax showed a single owner who had the car serviced almost religiously, which is one of the reasons we bought it.
The terminals look perfect, still shiny. The engine compartment itself is really clean. The only thing that stands out is that there's an aftermarket cold air intake, which we didn't notice before we bought it. Forscan also didn't recognize the truck when we hooked it up, making me wonder if it may have been tuned, but I haven't seen any confirmation that someone modified the ECU yet.
But I was wondering if maybe the battery had died at some point. I'm debating clearing the codes (now that I have a copy) and seeing if any pop back up.
Pittsburgh, PA
Chrissbu - any resolution to this?? My 2018 max platinum w 48k miles just had the identical behavior/messages on the console tonight. Ughh I've had a ton of problems with this vehicle. I'm also in Pittsburgh, ironically! An initial restart and the messages came right back and still it was in limp mode. After another restart it seems the wrench is gone and it's not in limp mode, but the check engine light is on (assuming DTCs are stored...I'll have to read them out).
Mr Big
Tampa Bay, Florida USA
My 2021 Explorer shuts things off all the time because my wife has only driven short trips. Currently the mileage is 5k+ after 2.5 years.
If we go on an interstate trip, lane assist, automatic shutoff, etc. start working again. Dealer said it is normal due to battery drain shutting features off.
bobward757
Did you get the Ford warranty or a third party? Ford will sell you the original bumper to bumper up to 125K with $100 deductible. It's saved me thousands on the little annoyances that eat labor time quickly.
Pittsburgh, PA
I was considering purchasing the extended Ford warranty for my '18 MAX Platinum, which has been a total rolling problem generator. Latest is a leaking water pump and the rear AC evap is leaking refrigerant. But the CSP warranty is super expensive. $100 deductible makes the CSP standard $5832 over 36 months. The "CSP ultimate" is $7848 over 36 mo with a $100 deductible. It's so expensive that I'm not sure it's worth it - although, if mine keeps up with having major problems at the rate I'm going, I'd be saving money in the long run! I wonder how much of a hassle it is to get things approved/covered? I can't find a comprehensive list of items - only vague high level items such as what they show on their Ford Protect website about the CSP program. Not sure what to do. I'm replacing the water pump myself this weekend.
