puddle light woes!
jk21
manila
hello guys! i have a 2008 GEN 3 Expedition with almost 50k miles. i just got it 2 weeks ago.
at first i thought, my puddle lights are not working. so i changed it to LED bulbs. but still, no lights. 2 days ago, i tried familiarizing myself with all the buttons. when i turned the dim dial to max, my puddle lights went on! but that's it.
puddle lights should turn on when you open the door or unlock the button from your FOB right?
help.
help.
LED lights my not work properly in the circuit.
The puddle lights on my 2015 turn on with the door opening, or the unlock button on my fob - but only during low light situations.
I think the light sensor on the dash has an effect on what lights turn on with an open door or the fob.
J
jk21
manila
thank you very much for reply. the LED bulb works fine when you turn on the dimmer dial to the max position. this still gives me the puzzle. thanks again.
JimR_TN
Middle TN
I have LED puddle lights in my 2007, they work fine. They come on with the interior lights via the FOB or opening the door.
J
jk21
manila
that is what i know how it should function. i dont know if its related but,
1. the dome light in the cargo area near the tail gate, it will only turn on when you slide the button to on. even if you slide it in the door section, still no light.
2. the dimmer dial near the steering - it doesnt dim the interior nor the instrument panel. when you put it on the max, then that's the only time it will turn on all the interior and puddle lights.
JimR_TN
Middle TN
Definitely sounds like a switch or wiring issue. Wiring could also include whatever module that controls the lights. All of my interior lights are also LED and they all work with the switch or the door including the one in the cargo area.
J
jk21
manila
wondering if i reset the battery and if that will work...
DeafBringer
Phoenix
Sounds like you might have an SSV or XL expedition with the interior/puddle lights turned off?
edyk1986
