Liftgate Button Removal
Zerokoo149
Utah
I'm trying to figure out how to remove the liftgate button that is in the liftgate to replace it. The button pictured in this thread:
I don't to start prying at it since I don't want to mar the plastic around it. I imagine it's a fairly simple removal process, but I'm not sure if I have to pop off the whole panel and remove from the inside. Has anyone on here done this before and could tell me the best way?
I already checked other threads and youtube, but wasn't able to find anything.
Thanks in advance!
LegalBrief
zephyr Cove, NV and SFO
You take off rear panel with a soft plastic trim pry tool, then you can release the switch from the rear and or pop it out. Otherwise you will scratch
Z
Zerokoo149
Utah
Thanks for confirm, only took about 3 mins to pull the panel off.
Funny enough, I saw immediately that the switch was operating perfectly once I popped it out of the housing. As soon as I would put it back in, it would start sticking again. I just shaved a little plastic around the 4 sides of the opening with a utility knife, I had to do it a few times inserting and taking the button out. Finally after the 3rd or 4th "shave" it started working fine and hasn't stuck since.
Everything looks factory again once I reinstalled the button, in case anyone else runs into the same issue with the button sticking. Total job about 10 minutes and $0.
Michael D Morris
As the others have recommended, I used a soft plastic trim tool and the button popped right out. No need to remove any panels. A new button (switch) was about $28 at the Ford dealership.
5280tunage
colorado
I have a similar post on here where I detail part of the design flaw with these buttons. there is nothing mechanical that provides the return force for the button, other than a flimsy rubber filament. If these were maybe designed more like a keyboard key that has springs that return the key's to their resting position, it might last longer. In cold weather the rubber becomes stiff and functions even worse. I put a little silicone lubricant in mine the last time I took it apart, that also seemed to help a bit, but about a year later I'm feeling it stick again, especially as the days are getting colder, just a cheap flimsy design.
rwbana
Utah
Can you give some more detailed instructions on how to remove the liftgage panel? I've seen some videos on YouTube and it looked pretty involved...more than 3 minute job as indicated by another user. I think I'm going to have to shave a little off the trim around the button because dealer wants $900 to do it.
Vin_mac
Would you mind sharing the links to the YouTube video's? I can not find any? Mine is sticking too and the dealer said $29.91 for the part. I just need to see it done before I try to attempt. Thanks for all the help!
spo0587
Mississippi
Can someone confirm the trim piece. Is it the small piece that has the instructions on how to adjust or are you talking about the entire real shell of the back gate? Mine is sticking and driving me crazy!!! I have the pry tools already just need to confirm
Shan
Arkansas
I made this today. Maybe this will help some folks out. I was having the same problem and I was wanting to watch a video to see what I was getting into before I began the process. There maybe a better way to do this, but it's what I did.
