GEONV
Ok, I bought a 2006 Ford Expedition from a lady whose mechanic was throwing parts at it trying to fix a crank but no start issue.
I've been going through things one at a time to verify various things.
Her mechanic had put this laundry list on- 2 new camshaft position sensors, O2 sensor right upstream, mass airflow sensor, fuel pump driver module, fuel pump, battery, fuel filter, air filter, fuel rail pressure sensor, spark plugs.
When I first started diagnosing it- I found no fuel pressure. I tried starting it with starting fluid and it didn't even sputter- which made me think ignition was the problem. Clearly needed to get the fuel pump working too, but important that it wouldn't start with starting fluid.
I checked the various fuel pump systems and found them all to be functional- but the ground on the frame was bad so i fixed that as well as the other ground wire nearby. Fuel pump now turns on but only has 7 volts at module output- pull codes- high fuel rail pressure (they just put a new sensor on it). I removed connector and jumpered source 5v to pressure sensor- ECU reads 5V, jumpered it to ground- reads 0v. same with fuel temp sensor. Plug in sensor and data log it- it occasionally spikes to 5v and then back to 4.3 and then sits at 5v. get a p0193 code. replace the sensor- now it behaves properly and shows the cranking desired pressure is 57 psi- measured pressure is 54.7 while cranking. no more code. Can smell fuel in exhaust as it cranks but no trying to start up.
Check coil connectors- 12v to connector and grounds intermittently as ecu fires coil. same thing for injectors. Pull a coil off and hook up a spark plug and ground it- really weak spark but it does fire. check other side also really weak spark. Won't start with starting fluid.
check several more grounds- nothing terrible. by the fuse box there is zero rust which was surprising. pulled all of the grounds I found off and sanded to sheet metal. one to left of ECU, on behind the ECU one to right of ECU and the two next to the fuse box. add another ground cable from battery to engine and from engine to body just to be sure.
Check ECU ground pinouts to battery negative 0.8 ohms resistance, same to engine block.
test the coil capacitors- one has continuity with ground the other doesn't. Order a new one. I don't think this would prevent it from starting though right?
I removed cam sensor plugs and still no start. plugged them back in
I had replaced crank sensor as it was still stock and thought it could be providing an odd signal. no start.
MAF sensor responds while cranking, cam sensors and crank sensors show synch, ignition timing while cranking shows 10.3 degrees advance.
I hate to just throw parts at it, especially since all of the coils I tested showed weak spark- that just felt like it would be the ignition coil ground. but the wiring diagram I found shows the coils ground through the capacitors and the ECU. And checking the ECU it has good grounds. It seems unlikely for multiple coils to fail at once.
I also jumpered a hot wire to the fuel pump to bypass the fuel pump relay to see if that made a difference- no difference- has the 12 volts coming out of the fuse box, but just wanted to test it.
Any ideas? I'm running out of things to check. Though I do suspect there to be an extra ground I haven't yet found. As a test I checked resistance between the fuel rail pressure sensor connector and battery negative and it read 0.8 ohms the same as the pcm pinout did.
