PRB module location
Dennis48755
Caseville, MI
If your referring to the Power Running Board Module, maybe this will help.
Dennis
HazBeen
Great Lakes
From the 2018 Expedition Workshop Manual, Running Board Control Module (RBM) removal and installation procedure is attached below...
Good luck!
  • Running Board Control Module (RBM) - Removal and Installation - 2018 Expedition Workshop Manual.pdf
rugedraw
Miami, FL
What software is this or where do I get it? Thanks!
That is from Ford's PTS website. Dealers and Ford employees only can access it. You can pay for access if you want. I think they charge $28 for 72 hours or something like that.
Left Coast Geek
Mid Left Coast
interesting, my 2019 Expedition/Navigator wiring diagram shows it there for the Navigator, but shows the '19 Expedition on the floor about under the drivers seat.
HazBeen
Great Lakes
Similarly odd, the 2019 Workshop Manuals show Exp/Nav with non-identical lower dash mounting, while each 2019 model's Wiring Resource shows both dash & floor mounting without identifying differing views to either model -- per PDF documents attached below...
In 2022, the RBM moved to Exp/Nav's inside/rear of Center Floor Console:
  • Running Board Control Module (RBM) - Removal and Installation - 2019 Expedition Workshop Manual.pdf
  • Running Board Control Module (RBM) - Removal and Installation - 2019 Navigaator Workshop Manual.pdf
  • Running Board Control Module (RBM) - Connection C3313A-C3313B Dash Location Illustration - 201...pdf
  • Running Board Control Module (RBM) - Connection C3313A-C3313B Floor Location Illustration - 20...pdf
